336whp!?!?!!? Well sortof.... Crazy Plenum Test
Old Aug 3, 2009 | 07:36 PM
  #41
tilleys99's Avatar
tilleys99
good numbers but kinda confused on what exactly was done... does it have multiple spacers or is it just a wide open intake manifold?
Old Aug 5, 2009 | 05:22 PM
  #42
T_K's Avatar
T_K
The upper collector was lifted during the run, and in doing so it functions as if the upper collector weren't there at all. I believe the long bolts are in place, so they were easily able to align it with the lower when necessary. So yes, essentially just a wide open intake manifold.
TK
EDIT: I'm curious to know though, if you guys have tried measuring the manifold vacuum while the car is in motion. Seeing as your car no longer requires a MAF sensor, it can be as simple as plumbing a piece of pipe to about where some people have their Z nostril. Something like tuning the AFR on the dyno, then logging it while in motion and see if it starts to go lean, and at what vehicle velocity. Just a thought.
Old Aug 5, 2009 | 05:44 PM
  #43
norapat01's Avatar
norapat01
I'll be awesome if they can come up with something along this line for DE 350Z
Old Aug 5, 2009 | 06:24 PM
  #44
tilleys99's Avatar
tilleys99
wouldnt this cause MAF voltages to be all messed up?
Old Aug 6, 2009 | 04:38 AM
  #45
T_K's Avatar
T_K
They use stand alone. No MAF.
Old Aug 9, 2009 | 07:44 PM
  #46
SGSash's Avatar
SGSash
Vendor - Former Vendor
TK,
We haven't measured vac, however without using any MAP sensor trimming, the AFRs are the same on track as they are on the dyno, infact if anything they go rich rather than lean, so there is no big ram air effect in action. There are plans to build a new intake out of carbon with a new airbox however!
Sasha
TK
Old Apr 23, 2010 | 12:54 PM
  #47
Vader007's Avatar
Vader007
Talking HR?
Originally Posted by Z1 Performance
The ports are not the same shape on a DE vs HR
Can it be done? sure - would require a CNC'd adapter (a fairly beefy one too) to allow the HR manifold to the DE head. It's been done before, at least on one of the RJN race cars from the UK. No idea if it proved worthwhile, or any results. You then run into the issue of controlling the dual throttle bodies with the factory ecu. Again, doable yes, but not sure if its worth the time/money/effort. You would also need to double the injector size, which again just adds more $ to the equation. I'd suspect you have hood clearance issues as well
Sorry for bumping an old thread.
Adam what about using the HR plenum/manifold with only one throttle body?
Sealing off the other side and using it only for its design?
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
