Hydraulic lifter buckets
Old Feb 26, 2010 | 05:10 PM
stock07g35s's Avatar
stock07g35s
Default Hydraulic lifter buckets
Has anyone put a reground camshaft in their vq? The hydraulic bucket lifter should pump up to a smaller base circle camshaft. Specifically, I am looking at HR applications. In de's was there a limit on how much smaller you could make the base circle and still have the lifter make good contact? Input, if you have any experience or knowledge about this. Thanks.
Old Feb 26, 2010 | 08:20 PM
GT-2 350Z's Avatar
GT-2 350Z
The VQ does not have hydraulic lifters. The buckets come in different thicknesses to set the clearance. I have run Nismo heads in a VQ30 and a VQ35 and there is a tiny cap that fits over the top of the valve and the bucket then sits on the tiny cap to make up the clearance for the reground cam.
Old Feb 27, 2010 | 08:43 AM
stock07g35s
Thanks for the reply. I have not seen shim kits for sale with the cams for sale. I assumed this meant they were hydraulic. How much are shim kits for these engines?
Old Feb 27, 2010 | 12:08 PM
GT-2 350Z's Avatar
GT-2 350Z
The caps came with the heads so you might call Nissan Motorsports at 888-833-3225 and see if they are available.
Old Feb 27, 2010 | 02:51 PM
QuadCam's Avatar
QuadCam
there are a few things you could do if you want to regrind your cams. you could use longer valve valves, you could buy thicker "buckets", or you can buy the adjustable buckets from supertech (basically a bucket with various shims you can buy.)
....and as someone esle said, they are not hydraulic buckets in these engines.
Old Mar 24, 2010 | 08:00 AM
Zazz93's Avatar
Zazz93
Not sure if you got this sorted out yet, but I also found people selling bucket on ebay, and some Nissan tuning shops may keep some from past jobs they may be willing to sell/trade, otherwise they are $25-30 each. I also heard some guys didn't have to change a single bucket (maybe move a few around) with the cam changes. You won't know until you get the cams in the heads.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Brantwilliams13
Sep 16, 2015 05:03 AM
rudypanama
Feb 24, 2004 09:43 AM
