View Poll Results: Going from 2in exhaust,to a 3in, longtube header, 2.25 Ypipe,on 8000K ITB Rev make?
1-5WHP
12.66%
5-10WHP
17
21.52%
10-15WHP
13
16.46%
15-20WHP
20
25.32%
20-30WHP
19
24.05%
Voters: 79. You may not vote on this poll
Kevin's VQ35DE NA Build Epilogue..
Old Mar 30, 2010 | 11:54 PM
  #41
kgkeen101's Avatar
kgkeen101
Originally Posted by gabe3d
I finally understand your graph now! I've been wondering what the top dyno run connected to below 5k, but it's basically you plotting it based on your other video.
It's really interesting that both setup realizes max power at a very similar rpm and by looking at your previous manifold I noticed that it's a log style one. It seems that the entire power curve is just shifted upwards by 20-25whp, is that also true down low? I would have expected a more gradual increase in power as rpm climbs. Too bad you don't have a torque curve on there.
When I get some more tuning in I'll post more info. There's more in it we just threw the tune together to get a before/after going.
The cams are a limiting factor too though, small cams 261s. Its basically an increase in the entire powerband. And extending the power out further in the rpm. VS the restrictive stock IM where power peaks and drops immediately.
Old Mar 31, 2010 | 12:19 AM
  #42
gabe3d's Avatar
gabe3d
At first I was expecting a drastic change in peak power location similar to the car that Injected did with the ITB, where it saw a lateral shift of 1000 rpms. Your car didn't exhibit this but the peak power and the way the power drops off on your car and theirs are almost identical with the ITB. His BC272 cams wouldn't be considered too large by any means either and on top of the 4.15L displacement it would be considered even less so. It just seems that the stock log like manifold on your maxima engine seems to be quite rev friendly. Do you plan to swap out the cams any time soon?
Old Mar 31, 2010 | 12:29 PM
  #43
niZam's Avatar
niZam
I've done some research on using the maxima intake manifold on a Z. Has anyone here tried it? I've read about guys putting Z lower and uppers on there Maxi's and loosing power. Guy's with Maximas are easily putting 270 to the wheels with bolt ons, wondering if the manifold is a big contributor.
Putting on the Maxima manifold requires the lower and upper peice, lower has the fuel rail on it I believe. This along with the SSID modification might yield a better system than the stock 350.
Anyone wanna try?
Would most likely require an extensive re-tune to take advantage of it.
Old Mar 31, 2010 | 06:08 PM
  #44
kgkeen101's Avatar
kgkeen101
Not for a while, want to get track times in and the rest with what I got, larger cams more tuning and more car incapacitated haha. I want to have fun with what I've made for a good while I'll fine tune it though in the coming months when the shop has time and isn't busy as hell. I would do 290 cams probably if/when I do go back in
Old Mar 31, 2010 | 07:53 PM
  #45
INTIMAZY's Avatar
INTIMAZY
Keep in mind the front wheel drive powertrain is naturally more efficient at putting power down to the wheels. They can easily dyno 5% higher due to being FWD alone (dependent on dyno of course). Now, max's laying down over 300fwhp with their manifolds would be interesting.
Old Apr 1, 2010 | 12:27 PM
  #46
niZam's Avatar
niZam
I've always been under the impression FWD trannys are less efficient. Maybe I've always assumed the FWD is an auto. Auto is less efficient obviously. But a FWD manual is more efficient than a RWD manual? Less drive train mass i guess.
Learn something new every day. Sorry for getting off topic.
No one with a Maxima intake mani on a Z?
Thanks
Old Apr 5, 2010 | 06:53 AM
  #47
deckdout2's Avatar
deckdout2
Hopefully, the wait will not be prolonged for you.
Old Apr 9, 2010 | 06:27 AM
  #48
kgkeen101's Avatar
kgkeen101
With no means of getting cold air from outside the car (horns hover at the top of the hood), I had the hood vented to release all the heat rising to the top of the hood that the horns are sucking in. While running the car hard, the horns end up sucking up a ton of heat as you can see they're located right at the top. Intake temps entering the horns should see up to a 30degree temp drop because of the setup we're using. My wife picked out the design and the waterjet did the work. Gota get some mesh and we'll be good to go.
Old Apr 13, 2010 | 08:06 AM
  #49
kacz07's Avatar
kacz07
I am becoming more and more interested in this setup... nice work!
Old May 21, 2010 | 03:13 PM
  #50
Ivory's Avatar
Ivory
Ive built a box for the setup to achieve ram air from the vented hood. Let me know if you want me to shoot you over the design and a shop can fab it up.
Old May 21, 2010 | 03:40 PM
  #51
kgkeen101's Avatar
kgkeen101
Sure that'd be cool send me the design and I'll take a look at it!
Old May 27, 2010 | 04:06 PM
  #52
gabe3d's Avatar
gabe3d
Hey Kevin, something is up with your account. Can't send you PMs.
Old May 27, 2010 | 04:14 PM
  #53
MI 35th's Avatar
MI 35th
OGPremierMafia
very nice subbed for more results.
Old May 27, 2010 | 04:15 PM
  #54
03threefiftyz's Avatar
03threefiftyz
Hes been banned......
Old May 27, 2010 | 04:25 PM
  #55
gabe3d's Avatar
gabe3d
Doh, he just PMed me this morning.
Just saw that exhaust thread me made...
Old May 27, 2010 | 04:27 PM
  #56
03threefiftyz
Looks like a temp ban....he should be back soon enough.
Old Jun 4, 2010 | 02:20 PM
  #57
kgkeen101's Avatar
kgkeen101
Back yeah, momentary ban lol. Won't happen again =)
Old Jun 4, 2010 | 03:09 PM
  #58
kgkeen101's Avatar
kgkeen101
Alright, just a little update. I made 315whp. On ebay shorty header, VQ30 ypipe, and a 2.25OD, around a 2in ID exhaust at its smallest choke point... Don't ask why I'm just an idiot for not measuring what I paid for 3 years back. Anyway long story short.
I'm pulling the motor out to correct a couple things while I'm pissed about the whole exhaust ordeal. A few photos to entertain the eyes.
Torn bushings in my control arms...
New stillen front sway bar while is is convenient to get to. My boy standing in the engine bay without motor haha.
Engine just hangin.
Old Jun 4, 2010 | 03:15 PM
  #59
kgkeen101's Avatar
kgkeen101
Added a fun poll too. VOTE!
The question, I made it as short as possible to fit. The long version of the question is the following:
What will going from an ebay shorty header/VQ30 ypipe 1.90in I think or so, 2.25OD / 2in ID exhaust at its smallest choke hold TO an Altima long tube header, 2.25 Y-Pipe, and a 3in ID exhaust (1in ID upgrade) proper exhaust make on a cammed etc. 8000 revving ITB motor make?
Let me know your opinion! Should be interesting. Post your guesses on the HP difference. As you can see 315 whp was made on a choked motor... Let us see what she really makes with proper back pressure relief. Especially at 8k RPM, lota lota air flow there.
Old Jun 4, 2010 | 03:41 PM
  #60
gabe3d's Avatar
gabe3d
You have a picture of the two headers?
