Power Loss, mostly stock HELP
Old Mar 27, 2010 | 09:15 AM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Default Power Loss, mostly stock HELP
Wasn't exactly sure where to post this so I sorry if this is in the wrong section. So for the most part my car is pretty stock except for a JWT popcharger and MD 5/16 spacer. A couple weeks ago I noticed a slight power loss and for the week or so I wasn't positive if there was something wrong or if it was just in my head. So I checked under the hood to look for anything visibility wrong and noticed my popcharger air filter wasn't even connected. There was the stock piping and then about a 2 inch gap and my air filter. So I reattached it and figured that would fix it. Nope, one of my friends thinks its just in my head but It seems most noticeable to me when I go from a complete stop like at a stop light. Seems like I have to give it more than I used to for my driving style.
I don't no if this light has always been on or not and I can't even find out what it means. I looked through the manual but couldn't find anything. Thought it meant low coolant at first but I checked and its fine.
Is there any chance when I filter was off my popcharger that something bad got sucked in? Any common things that cause slight power loss. Thanks for any helpful input.
Old Mar 27, 2010 | 10:45 AM
bmccann101's Avatar
bmccann101
Default gap
so you began running an insaine air/fuel mixture due to tons of exra air comming into the engine, ( didnt catch if the gap was before or after the MAF) and your ECU is doing its best to compensate fuel leaning or enrichment..or is all the way into limp mode.
Search for the "technosquare ECU reset" procedeure...do it, Drive for a few days, I bet 50 bucks problem solved. It will take a few days of start n stop and driving conditions to relearn the curves.. but yeah, your air gap causees major ECUsettings issues.
Enjoy your weekend, your car isnt dead.
Old Mar 27, 2010 | 12:29 PM
seank426's Avatar
seank426
Tried that the other day actually but I'll try it again and make sure I do it correctly and then give it a couple days. If that doesn't help anything else it could be? Thanks for the input bmccann
Any idea on that light?
Old Mar 27, 2010 | 02:08 PM
13ringinheat's Avatar
13ringinheat
That light is a stock light for temperature. I am not sure what if anything is wrong with your car but the light is not one of your worries.
Old Mar 27, 2010 | 02:54 PM
SatchScream's Avatar
SatchScream
Fasten your seat belt!
Old Mar 27, 2010 | 03:18 PM
seank426's Avatar
seank426
So is that light on for everyone? It just sort of annoys me as I for some reason I don't remember it always being there.
Old Mar 27, 2010 | 06:45 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
So I get in my car after work today and start it and it my gas gauge is alll the way to completely empty and my dash gash is just flashing 200 miles till empty so I try to figure out wtf happened and after 30 seconds turned the car off and back on right away and it was fine. Not sure what that means if anything but figured I'd post it in case someone knows more.
Old Mar 31, 2010 | 03:34 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Reset my ECU gave it a couple days, it seems like its still there. I just got test pipes and HKS exhaust yesterday. Anything else you guys could think of that could cause lower rpm power loss. Dirty or bad spark plugs or anything?
Old Mar 31, 2010 | 03:43 PM
Entaille's Avatar
Entaille
why are you ordering more parts when your car has a problem? address that first.
SoCal-Zzzz's Avatar
SoCal-Zzzz
hks and tp for $650 = take them as fast as possible.
Otherwise I would have waited
you live in everett I noticed I used to live in Sammamish.
Old Apr 6, 2010 | 09:32 PM
Manjot's Avatar
Manjot
It's the intake, take it off and go back to stock.
Old Apr 7, 2010 | 05:36 AM
Zazz93's Avatar
Zazz93
Do you remember going through any especially dirty, dusty, or partical filled air while the filter was ajar?
Old Apr 7, 2010 | 02:22 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
It isn't the intake I had it on for months without any issues.
I don't think I went through any dusty areas but anything is possible. Are you thinking something got sucked in that shouldn't of?
Old Apr 7, 2010 | 02:28 PM
godzilla619's Avatar
godzilla619
Try cleaning your maf sensor. If it gets dirty it really messes with the ecu. Make sure you go to an autoparts store to buy the correct cleaner or you will have to pay a couple of hundred bucks for a new one.
Old Apr 7, 2010 | 02:29 PM
Zazz93's Avatar
Zazz93
Yeah, it doesn't take much dust and dirt sucked in to an engine before damage occurs. It will lose compression and power and just run badly. To test run a compression check.
Old Apr 7, 2010 | 09:21 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Any DIY guide on how to clean your maf sensor?
Old Apr 8, 2010 | 07:54 AM
godzilla619
Get the spray from the autoparts store. Take off your sensor. It's that plug that you had to swap from your stock intake to your aftermarket one. Spray the cleaning solution onto the metal part of the sensor. Read directions of cleaner for best results. Hint do not have it soaking wet with the cleaner or your will need to replace it.
Old Apr 14, 2010 | 11:13 AM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Got it and used it along with an ECU reset, put about 70 miles on the car since. Still feels like I'm really lacking in the lower rpm. I no the exhaust and tp don't help low end but idn it doesn't seem right. Could spark plugs have anything to do with it? Any other ideas?
Old Apr 14, 2010 | 12:13 PM
Zazz93's Avatar
Zazz93
Always good to check, but seldom the cause. What would be good to check when your in the spark plug area is the compression. Really easy to do once you have the plugs ready to come out. The tester costs about $20-$40, so its reletively cheap as well.
Old Apr 14, 2010 | 12:15 PM
Zazz93's Avatar
Zazz93
You'll want to see all the cylinders within 10% of the others and should read higher than 160 PSI.
