High-Comp Time!
Old Apr 5, 2010 | 06:29 PM
SGSash's Avatar
SGSash
Vendor - Former Vendor
Default High-Comp Time!
Hey Guys,
As I've mentioned here and there it's time to bump the compression and see what happens. JE were happy to work with us and helped us create a custom set of pistons with a few very neat features.
This is my first engine build so I wanted to keep it relatively affordable so that if it grenades I don't lose too many tears over it. For that reason I just went with a revup oil pump for some added RPM ability as well as affordable Eagle rods - which actually appear quite nice, but what do I know. The crank was dynamically balanced for the rods and pistons, and the machine work was done by a local shop that I've worked with before.
Finally had some time to put the components together and as I said before, it's my first engine build so I hope everything runs smoothly. The rod oil clearance is a little bit tighter than I'd like (or I think I'd like), but should still be acceptable. I'm using all Nissan bearings as I've run many endurance races with them without failure, so why fix something that isn't broken right?
Here are the details and some pictures of the build:
JE Pistons are designed for 12.3:1 compression, upon fitting to the heads I realized there was zero clearance to the spark plugs so some reliefs were cut. A small washer to raise the plug will still be required, or changing to a side electrode style plug. The pistons also had some weight reduction features to help with the extended high RPM use, such as manual under-dome material removal, skirt thinning and a thinner, stronger piston pin. There are also some lateral gas ports in the top compression ring land to help prevent ring flutter, which is no good for keeping all that compression in the cylinder!
Everything else is standard in the build, Clark from JWT has suggested using the HR headgaskets to help balance the water temperature across the two heads, some ARP main studs and head studs and that's about it!
I had the machine shop do me up a nice sleeve to aid with piston installation. It has a gentle taper to the block diameter that allowed me to load the piston and compress the rings and then just pop it right into the bore. V8 guys use them a lot and it just seems like a better method than clamping the piston with some universal tool. Best $80 I ever spent.
Old Apr 5, 2010 | 07:01 PM
03threefiftyz's Avatar
03threefiftyz
MOAR!
Old Apr 5, 2010 | 07:37 PM
blue350zed's Avatar
blue350zed
Nice! Keep us posted.
Old Apr 5, 2010 | 08:16 PM
kacz07's Avatar
kacz07
Can't wait to see how the intake responds to this engine. Keep the updates coming.
Old Apr 6, 2010 | 05:07 AM
rcdash's Avatar
rcdash
Why would JE design VQ35DE pistons that hit the spark plugs? So what fuel will this motor be running?
Old Apr 6, 2010 | 07:42 AM
1cockyZ's Avatar
1cockyZ
Wiseco makes those sleeves and there $30, but its worth every penny for sure. I hope the heads are getting a race valve job or a little attention because from the factory there is some nasty gouging just above the spring seat. But damn you guys have taken intake and exhaust to a whole new level so now that you can rev it out with a bump in compression who knows.
Old Apr 6, 2010 | 07:54 AM
BornSlippyZ's Avatar
BornSlippyZ
Sweet!
Old Apr 6, 2010 | 10:25 AM
tuko316's Avatar
tuko316
Should be interesting.
Old Apr 6, 2010 | 11:19 AM
niZam's Avatar
niZam
Now thats hi comp on the VQ. 375 at the wheels sounds good?
Audi runs 12.5.1 in the R8 V10 FSI. Pump gas should be fine if tuned right?
It's not JE's fault the pistons hit the plugs. The engine wasn't designed to run such hi comp. Thats why its custom.
Cant wait for results.
Keep up the good work
Old Apr 6, 2010 | 11:38 AM
Frostydc4's Avatar
Frostydc4
Keep us posted
Old Apr 6, 2010 | 11:42 AM
Frostydc4's Avatar
Frostydc4
He will have to run a more conservative timing map but it should be fine.
I ran 13:1 on pump on my old Honda.
Old Apr 6, 2010 | 11:58 AM
plumpzz's Avatar
plumpzz
Static compression pressures can be very different from the dynamic compression pressures in the cylinder.
Old Apr 6, 2010 | 12:48 PM
Nathan's Avatar
Nathan
[QUOTE=niZam;8276721]Now thats hi comp on the VQ. 375 at the wheels sounds good?
The Audi & for that matter all the late model high performance motors that use
11.5.1 CR & higher utilize direct injection for combustion control.
The DE @ 12.5 on pump gas will be using a timing map more similar to a FI motor & while power will be increased, detonation will be an ever present worry if the conditions vary from optimum. EG: High air temps, high water temps, pump gas not to spec.
With a high oxygen, high octane race gas the real benefit of HC will be realized
Old Apr 6, 2010 | 01:31 PM
Nathan's Avatar
Nathan
It will be very interesting to see the power increase that these pistons achieve.
In 2003 I had a talk with the boss of Nissan Motorsport South Africa.
They were the builders of the factory Paris-Daker rally raid Pathfinders.
In the conversation he said that the DE made good power up to 12.5 CR with very little to be gained above this. He also said to use the 46cc Nismo heads to increase the CR so as to keep the original combustion chamber & piston design.
Because of the intended use of the motor ( Long distance, high revving & high temp desert racing ) they settled on 11.0 CR but still made over 400 HP @ the flywheel by using Jenvey ITB's, Pectel ECU & some very high lift cams.
Old Apr 7, 2010 | 05:49 AM
Zazz93's Avatar
Zazz93
That's interesting because Nismo and Tomei both "seem" to advocate or at least suggest 13.5:1 could be worth while. But a Dakar Rally built engine will surely have different characteristics in mind not to mention the bottom end is probably the larger VQ variant.
Old Apr 7, 2010 | 08:21 AM
flecko28's Avatar
flecko28
I likeeeeee
In for more
Old Apr 7, 2010 | 11:36 AM
SexyRob's Avatar
SexyRob
awesome, cant wait to see what this does.
Old Apr 7, 2010 | 12:46 PM
bluezee's Avatar
bluezee
I cant wait to see what this brings! Keep up the great work!
Bob
Old Apr 7, 2010 | 03:32 PM
MREDDLE's Avatar
MREDDLE
SUB
Old Apr 7, 2010 | 07:04 PM
NA&CH's Avatar
NA&CH
In for the Win. Can't wait to see the results.
Chris
