DIY Build
Old Aug 26, 2010 | 07:35 PM
adrift_foolish1's Avatar
adrift_foolish1
Default DIY Build
So I recently acquired a 05' enthusiast from an 'authorized rebuilder' for cheap. Problem was that not only was there a dent in the drivers side rear quarter panel, from "being backed into" but also the frame was bent. Still, a couple grand later and I have a car in decent shape for a lot less than what you would normally spend on this year model.
I'm building the motor first, and turbo after it's broken in.
Removed entire rear assembly just to replace evap line that wasn't connected to the gas tank. Bought some Tein S-tech's to put on while I was at it.
Old Aug 26, 2010 | 07:47 PM
adrift_foolish1
Arias extreme 9.5, competition clutch stage 4 and flywheel, eagle rods, jwt s2 cams and springs,
misc. rear coolant bypass mod, revup oil pump, samco hoses, arp L19 head studs
Old Aug 26, 2010 | 07:51 PM
03LeMans350zed's Avatar
03LeMans350zed
sounds like a cool build but any pics?
Old Aug 26, 2010 | 08:24 PM
ImWeeZzel's Avatar
ImWeeZzel
in 4 progress
Old Aug 27, 2010 | 03:10 PM
MREDDLE's Avatar
MREDDLE
You are required to take many pictures and post them all. Good luck on everything.
Old Aug 28, 2010 | 12:27 PM
adrift_foolish1
I will! School keeps me from working a lot during the week though
Old Aug 28, 2010 | 12:38 PM
verdict.'s Avatar
verdict.
In for updates/progress. Good luck.
Old Aug 28, 2010 | 01:27 PM
Nathan's Avatar
Nathan
As this post is in the NA section I assume that this rebuild is not going to be boosted.
If my assumption is correct, why would you use low compression pistons ????
Old Aug 28, 2010 | 01:42 PM
0jiggy0's Avatar
0jiggy0
Looks like a wrong section error. Anyway DIY = **** to me. And I like ****.
Old Aug 28, 2010 | 02:41 PM
adrift_foolish1
Nathan, it will be. I'm making it a two part. Nothing FI will be posted in this thread though.
Since I'm here..
Old Aug 28, 2010 | 07:59 PM
adrift_foolish1
Old Aug 28, 2010 | 08:00 PM
adrift_foolish1
...i wish i knew how to delete dup posts.
adrift_foolish1
..and i'm done for the night. until next weekend, renting a torque plate then it's off to the machine shop
Old Sep 9, 2010 | 01:41 PM
adrift_foolish1
update: block and assorted bits are at machine shop. they're gonna do a bore and balance the crank. installing valve springs this weekend.
Old Sep 9, 2010 | 07:01 PM
adrift_foolish1
new and old valve springs
Old Sep 10, 2010 | 05:07 AM
MREDDLE's Avatar
MREDDLE
ADRIFT...... And everyone else. What Bobweight factor and speed (RPM) is your shop using to balance your crank? Also, I am sure they are but, make sure they are balancing the crank with the pressure plate, flywheel and crank pullie installed on the crank.
Old Sep 10, 2010 | 12:49 PM
adrift_foolish1
Everythings on it. I'm not really sure what black magic they're working to balance it though.
Old Sep 17, 2010 | 05:48 PM
adrift_foolish1
got the block and crank back from the machine shop today. wish i had kept the torque plate to double check the clearances. guy said he threw away the paper he wrote them on and i get a difference of up to .002 depending on where i gauge it.
Old Oct 1, 2010 | 07:41 PM
adrift_foolish1
Old Oct 1, 2010 | 08:09 PM
GreenGoblin's Avatar
GreenGoblin
looking good
