346whp @ 0 pounds of boost
Old Dec 30, 2010 | 07:38 PM
  #161
kacz07's Avatar
kacz07
Originally Posted by fwdnissanjunky
The lower the crankcase pressure the better low tension rings seal at high rpms.
This. I really want to keep the valve covers from leaking. I feel like allowing the engine to build crankcase vac would affect the valve cover seal, too. No?
Old Dec 30, 2010 | 08:46 PM
  #162
fwdnissanjunky's Avatar
fwdnissanjunky
I'll start another thread and do a write up.
If anyone has some valve covers laying around they could take pics of it would really help.
Old Dec 31, 2010 | 03:16 PM
  #163
Row2K's Avatar
Row2K
PM sent,
Sasha , whats the time frame you expect to have something available as far as the 90mm throttle body and intake setup?
Old Dec 31, 2010 | 11:40 PM
  #164
kof0127's Avatar
kof0127
Really impressive set up, I don't know if anyone knows that the Amuse 350z has similar set up, here is the link you can see the Amuse Powerhouse 350z mod list. http://www.*********.com/zwiki/Amuse_350ZThis also my dream setup for NA of course, but it is expensive with those nismo spec 2 cam and heads. Luckily we do have other US tuners like to challenge NA setup and push it to the limit, this is very impressive. Keep up the good work. Now I can hurry up and get the set up down.
Old Jan 1, 2011 | 09:58 AM
  #165
rich2342's Avatar
rich2342
Originally Posted by Row2K
+1
i'd be down
+2 if this is a bolt on compatible w/uprev and proven gains im sure there would be more than enough support.
Im looking to pull as much n/a bolt on power as I can from me DE.
Old Jan 7, 2011 | 08:46 PM
  #166
Sparks03Max's Avatar
Sparks03Max
And as far as VQ35 intake manifolds go, I'd put my money on a modified FWD VQ manifold beating a RWD manifold anyday...... but I don't know if it'd even fit on a Z or G.
I would love to see a 90MM elbow and TB fitted onto a SSIM FWD manifold. Seems like it would be a pretty easy job if you have the ECU capability to use a 90MM TB.
Old Jan 10, 2011 | 10:51 AM
  #167
the_coupe's Avatar
the_coupe
my inspiration
Old Jan 10, 2011 | 11:50 AM
  #168
MIKERNM1990's Avatar
MIKERNM1990
Old Jan 17, 2011 | 08:13 AM
  #169
fwdnissanjunky
It'll be on the motor we're building for our 200SX SE-R VQ swap.
Old Jan 17, 2011 | 08:50 AM
  #170
Sparks03Max
Cool, be sure to make a thread on maxima.org all motor forums!
Old Jan 30, 2011 | 10:23 AM
  #171
Sparks03Max
SGSash, did you happen to get any measurements of the original plenum volume and new plenum volume after the changes? Or if you don't want to give out specific info, was there a %age of engine size that you were shooting for? I'm in the middle of a FWD sheet metal intake project and any info would be helpful.
Old Jan 31, 2011 | 07:34 AM
  #172
Andrei's Avatar
Andrei
Is this how the cams clear the valve covers?
Old Feb 16, 2011 | 08:58 PM
  #173
nismo240r's Avatar
nismo240r
wow. . .excellent read. . .aside from some ******** threadjacking. . .
glad to see some R&D paying off and looking forward for future results!
Need to get some more HD vids up of this beast!
Old Feb 22, 2011 | 11:34 AM
  #174
SGSash's Avatar
SGSash
Vendor - Former Vendor
a little video from time attacking this year (watch in HD!):
http://www.youtube.com/watch?v=gCHosjqinpk
Old Feb 22, 2011 | 11:53 AM
  #175
rich2342's Avatar
rich2342
Sounds so sick...
Any other longer vids?
Old Feb 22, 2011 | 12:06 PM
  #176
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Sounds sick! How loud is your car?
Old Feb 22, 2011 | 12:26 PM
  #177
erichsherrill's Avatar
erichsherrill
me likey
Old Feb 22, 2011 | 12:40 PM
  #178
KingBaby's Avatar
KingBaby
Hardest Setting
alot to take in...
Old Feb 22, 2011 | 12:59 PM
  #179
2004Black350z's Avatar
2004Black350z
Exhaust Whore
how loud u ask? Indy car loud i reply
Old Feb 22, 2011 | 01:59 PM
  #180
Zazz93's Avatar
Zazz93
That comment reminded me of the old Champ cars... Most violent cars I've ever seen in person (dragsters not included). No dis-respect, but nah...
However, you have my vote on sounding like a propper race car.
