346whp @ 0 pounds of boost
Old Mar 18, 2011 | 10:26 AM
  #221
Resolute's Avatar
Resolute
Originally Posted by Zquicksilver
^^^ so ATI street damper > Fluidampr
but on the flip side... and if i'm interpreting this correctly, this is why i thought the Fluidampr was the better choice. broader rage of dampening vibration. i think of the crank ends like a (wobbling) hotdog, don't know why, lol!
It's not so much a "wobbling hotdog" as a bar with twist. If you and a buddy hold either end of a length of steel bar very tightly, and then your buddy tries to rotate his end while you hold yours, you'll feel the torsion in the bar as the bar tries to rotate in your hand. If your buddy then stops trying to rotate the bar, the energy stored in the bar will want to cause the bar to "unwind" slightly, and this energy will be released into your hands. The longer the bar, the more energy can be stored as torsion and then released as soon as the application of torque stops. The damper servers to help dampen the harmonic of this periodic twisting of the bar.
The Fluidamper is a viscous damper, which has been shown in several studies to dampen a broader range of harmonics. However, there are other considerations, such as pulley diameter and use with accessories, that also come into play when selecting an appropriate damper.
Will
Old Mar 18, 2011 | 10:49 AM
  #222
e30cabrio's Avatar
e30cabrio
Originally Posted by Z1 Performance
you can contact ATI for the exact amount of under/overdriving Sasha, I forget the %'s of under/overdriving- it might be in my thread too
edit - found it
https://my350z.com/forum/5859855-post567.html
Which pulley did you use Adam?
Old Mar 18, 2011 | 12:13 PM
  #223
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
its' on our site:
http://z1auto.com/prodmore.asp?model...ne&prodid=3206
Old Mar 18, 2011 | 01:54 PM
  #224
e30cabrio's Avatar
e30cabrio
Thanks.
Old Apr 15, 2011 | 07:23 AM
  #225
sabelotodo's Avatar
sabelotodo
those are some amazing results. i cannot wait to break into my girlfriends car. we are going to shoot for 300whp in her 350z NA and 300whp in my 2.0T genesis coupe, then its off to the races.
Old Apr 17, 2011 | 06:14 AM
  #226
1cockyZ's Avatar
1cockyZ
I have had both the ati and fluidampr. The ati is 6 7/8 od which overdrives the ps, and alt while underdriving the a/c. The total assembled weight is heavier than stock. The ati race pulley has a smooth outer shell that can't drive a belt and this is for race(drag) cars that have neither an alt or ps system. The ati is tunable via elastomer rings. The ati will actually rub the idler due to its size.
The fluidampr is now steel shelled, but it was always steel hubbed. Older ones were aluminum shelled with steel hubs. The fluidampr is a viscous unit and the same size as stock which makes it easier to buy belts when your **** breaks at a track day when your doing 135mph at pocono and your ps gives out, ati unit ftl.
The vq is internally balanced and all crank pulleys/harmonic balancers should be zero balanced. The balancing is accomplished via the counterweights on the crank. V8 engines that do not have enough mass to counteract the rotating parts actually have to have weights placed on the crank pulley. This is known as an externally balanced engine. The dual mass flywheels are just there to dampen drivetrain shock and there shear mass also dampens nvh from the engine. To dampen nvh in your exhaust you can use thicker wall tubing which is just adding mass. Clutch takeup will be different between an al ur pulley and a full weight dampener due to rotating mass.
Wrong thread, way off topic but the misinformation in the last page has to be corrected. Although the whole deal on the balancer countering the harmonics of cylinder firing was good.
Old Apr 17, 2011 | 11:19 AM
  #227
SGSash's Avatar
SGSash
Vendor - Former Vendor
This is on par with what I've experienced. Thank you.
Old Apr 17, 2011 | 12:26 PM
  #228
Resolute's Avatar
Resolute
What misinformation were you correcting?
Will
Old Apr 17, 2011 | 05:26 PM
  #229
1cockyZ's Avatar
1cockyZ
If memory serves, the Fluidampr was backordered at the time, and had just been changed to use an aluminum center section, which I wanted to avoid. The ATI uses a steel center hub section, so no concerns with long term wear against the crank.
And something else that someone edited.
Old Apr 17, 2011 | 06:42 PM
  #230
tuko316's Avatar
tuko316
Are the fluidamprs still aluminum? Which is currently the better choice?
Old Apr 17, 2011 | 07:48 PM
  #231
Resolute's Avatar
Resolute
I thought both were steel hubs, but the Fluidamper used an Al casing. But 1cockyZ seems to be saying that the Fluidamper hub is also Al? If so, that's surprising, and a bit disconcerting for anyone looking to buy.
Will
Sasha: I heard that you sold all of your longtube headers. Are there plans to make another batch?
Old Apr 19, 2011 | 03:38 PM
  #232
1cockyZ's Avatar
1cockyZ
That was a quote, sorry. All fluidampr have steel hubs
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
