How much power do you predict?
Old Jan 24, 2011 | 10:45 AM
91180sr's Avatar
91180sr
NEW UPDATE .The heads are now getting a performance 3 angle valve job done as well due to lasck of seal and concerns of motor having blown headgasket and bad seals. Not sure how much comes out of that being done?
P.S.
this is getting way to expensive !!! thankgod ffor tax money other wise i wouldnt have done it.
Old Jan 24, 2011 | 10:59 AM
Alberto's Avatar
Alberto
Cranky FI Owner
270-280whp
Not worth the money for a DD, I would have found another used motor, put it in and saved the $$$$
Old Jan 24, 2011 | 11:48 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
P.S.
the heads come with a 3 way valve job from Nissan directly
Old Jan 24, 2011 | 12:11 PM
KA24DE's Avatar
KA24DE
Originally Posted by kacz07
With aftermarket cams (or aftermarket reflash/ems), you have two options:
1. Swap in a lower revup collector and increase volume w/ a big spacer/upper plenum (SG, SexyRob)
You are trading some power under the curve for peak power, but with exhaust cam phasing, this could be massaged. Additionally, with cams, it is possible to extend the torque band and, consequently, add or maintain peak power from 6300rpm and up. Maybe to 8k and beyond, but that's cam dependent. Extending the powerband after the peak makes up for power under the curve, but you need upgraded valve springs and shims to rev higher.
Or, as mentioned/employed by Adam and reiterated by SexyRob's intake dynos, myself, and Copec:
Do you know who did this? 1cockyZ, and guess what, he made the most power on a NONREV plenum. The issue is the revups runners are too short and large, and you're losing a lot of velocity. A good port job will open up the non revs runners, and allow it to breath about as well as a revup manifold, while offering more area under the curve. I DARE you to find a Revup manifold making more power.
2. Properly ported Non-rev lower collector and spacer/big upper plenum (Z1). A properly ported Non-rev lower collector will eliminate the dip and turndown in power that most DEs see around 6300 and shift peak to 6600rpm. After that, the cams will determine how far that extends. You really don't have to sacrifice any power under the curve with this method.
References:
https://my350z.com/forum/8590473-post156.html
Look at torque, peaks, and power to redline in SG's non-rev and Jmccarty's
_______________
A side note, a regular Non-rev lower collector, as seen in SG's build will peak at 6300, dip down, and then climb back up to near peak or above (cam dependent, SG, Jmccarty). I'm guessing that the airflow, although less than what is seen at the typical Non-rev peak, is still able to allow for sufficient torque to be produced, AFTER the peak and higher in the rpm range.
I need to support these observations with dynos, but I'm busy now.
The nonrev manifold geometry is bais towards midrange power. Removing some material, and porting the runners can allow for better high rpm breathing. The problem isn't just the runner size though, its the length as well, because the nonrev has longer runners (bais towards torque) vs the revup.
Old Jan 24, 2011 | 12:13 PM
KA24DE's Avatar
KA24DE
I'd get the biggest spacer you can. Motordyne has the 1/2" or Powerlabs has a 3/8th". Not sure what other options there are, but you can find a larger upper plenum like Crawford or APS. Keep us updated and let us know how it goes.
The porting of the lower collector should probably be under advice from someone like Adam at Z1auto or the like. The runners are what you'd be porting in the lower. They're much more sensitive to modifications than just making space in the upper.
I've never seen a spacer work on a revup manifold. I don't think plenum volume is an issue with that manifold.
Old Jan 24, 2011 | 01:06 PM
91180sr's Avatar
91180sr
So because they have a valve job doing it again or whatever means?
Yes its alot but when i say daily its my car I use for work... I do intend to play with my cars as I always have hopeing to get some track time to actually see how it does, Ive herd you never have really experienced your Z until you track it.
Old Jan 25, 2011 | 08:25 AM
Z1 Performance
Former Sponsor
If you are unsure of the integrity of any of the components you are doing (heads, block, whatever), then yes, of course it pays to have these things done, to ensure you are using sound components and that you won't have any unexpected surprises. That being said there really is no such thing as a "performance 3 angle valve job", - 3 angles are basically 3 angles, and that is how it comes from the factory. If those heads are damaged in any way, then yes, it certainly pays to invest and have them cleaned and inspected, and replace seals, etc. But short of that you're not going to net a gain vs otherwise stock heads. The more "angles" you do, the better the valve can seat itself. How much that might be worth (and how much it will cost) would be something to discuss with your machinist and will be dependant on several variables
Old Jan 25, 2011 | 03:12 PM
91180sr's Avatar
91180sr
yes after speaking with the shop I understand what is going on, the motor was not sealing on 2 cylinders and some valves when tested. Also they assume the motor had a blown hg and pretty much were doing the hole damn thing. I will post pics and dyno videos and all soon. thanks guys.
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
