what the maximum HEAD SKIM for VQ35DE
Old Mar 3, 2011 | 02:00 AM
Solid man's Avatar
Solid man
Question what the maximum HEAD SKIM for VQ35DE
Hello,
i have ALTIMA 2006 SE-R VQ35DE
i buy C8 cam A3505-N00C8 with spring
http://www.importpartspro.com/a3505n00c8g35.html
and Ferrea Valves 6000 Series Nissan 350Z VQ35 VQ35DE +1mm
and Cosworth 20000900 High Performance Head Gaskets .6mm
i wanna do head work
my question what the maximum HEAD SKIM?
i wanna go high compression from head
i hope u can help me
Old Mar 3, 2011 | 04:11 PM
bimmertech's Avatar
bimmertech
i don't think that nissan has a spec of what is allowable--after a quick glance all i saw was a max spec of warpage in which they consider the head to be junk.
most of the time on newer cars there is a zero tolerance on head shaving. if there is warpage the accepted method(in the aftermarket) is to heat the head and straighten it
i personally would not shave the VQ head at all considering the fitment of the timing covers/upper oil pan.
Old Mar 6, 2011 | 07:17 AM
0jiggy0's Avatar
0jiggy0
None. The timing chain would be off if you shaved it any realistic amount. Get new pistons.
Pleask
Dec 21, 2021 03:17 PM
AbyteZero
Sep 22, 2015 09:17 AM
torchkc
Sep 11, 2015 08:26 PM
