stock injectors
Old Mar 16, 2011 | 08:37 PM
mgrotel's Avatar
mgrotel
Default stock injectors
are the stock injectors close to being maxed out on a de? just asking cause im doing a high rev build and thought i might as well get new injectors while im at it, but then again, if the stock ones arent close to being maxed out, then there should be plenty of room for extra fueling with them.
Old Mar 16, 2011 | 08:42 PM
mgrotel's Avatar
mgrotel
stock are 330cc at 51psi, im considering going to a 380cc, but idk
Old Mar 17, 2011 | 01:26 AM
BabyZiLLa's Avatar
BabyZiLLa
I'm pretty sure they are 290 not 330.. I believe that's what I was told when I had them flow tested.
Old Mar 17, 2011 | 06:20 AM
mgrotel's Avatar
mgrotel
not sure, only guessing here, but probably because that 290 was measured at a static pressure of 43.5psi, i was talking about at max 51psi. the increase in pressure would make the injector flow more. but again, just guessing with that, i dont know much about injectors, that is why im asking here.
