the_coupe's NA build cp manley bc
Old Aug 24, 2011 | 06:36 AM
  #481
mgrotel's Avatar
mgrotel
haha, cause 400 bucks for a set of forged rods isnt good insurance, lol. thats funny. not to mention stock rods will probably last forever with 450 hp and 500 lb ft. come on...
Old Aug 24, 2011 | 06:54 AM
  #482
e30cabrio's Avatar
e30cabrio
Originally Posted by KA24DE
Problem with N?A builds come with people spending money in areas where they shouldn't bother. 1CockyZ and SG proved that headwork, cams and a good manifold are all that are really needed. But dump money into thos forged rods for 300whp, at least it will look good in your signature.
imho inexpensive rods (BC Sportsman) that include ARP fastners are the bargain of the century. If 4-500 is keeping you from doing a build, just get nitrous and when you blow your motor THEN you can get the right internals.
For my build I needed the right rods for the crank and pistons. But like you say it looks great in my sig (or will when I change it to reflect all of those things when they are actually in the car and not at a shop waiting to be assembled) AGAIN.
I have headwork and cams btw.
Old Aug 24, 2011 | 08:19 AM
  #483
thatv35guy's Avatar
thatv35guy
What’s another 500 when you just spent 1500 on just machine work, lol
Old Aug 24, 2011 | 09:18 AM
  #484
Zazz93's Avatar
Zazz93
Granted the VQ has forged rods to begin with, so I see his point there, but to expect the bolts to hold up to the thrashing that it requires to run aggro-cams and a high flow head is not gonna end well. Considering the rod bolts cost about a couple of hundred its almost a no brainer to get a system that is designed for the task, not to mention the recip. mass saving in some rod sets.
Old Aug 24, 2011 | 09:31 AM
  #485
mgrotel's Avatar
mgrotel
ill be honest, i thought stock rods were cast
Old Aug 24, 2011 | 11:31 AM
  #486
e30cabrio's Avatar
e30cabrio
That's what I was getting at.
Old Aug 24, 2011 | 12:03 PM
  #487
Zazz93's Avatar
Zazz93
You could be right, I'm going off a vague memory of something I read. I didn't bother to check when I rebuilt mine, old rods went straight in the trash.
Old Aug 24, 2011 | 12:15 PM
  #488
Fixxxercask's Avatar
Fixxxercask
I would want the better rods and bolts for higher revs for road racing. Not so much the HP. Like you said, the stock rods/bolts are good for a lot more HP, but not for revving real high.
Old Aug 24, 2011 | 12:18 PM
  #489
mgrotel's Avatar
mgrotel
so the stock rods are good for quite a bit more power? i was being sarcastic in my earlier post, so i dont know.
  #490
the_coupe's Avatar
the_coupe
forged internals are a good decision either way if you plan on juicin your motor up...whether it be nitrous, s/c, or turbo. now if you do it to have a relatively stock motor, then why bother spendin the extra money. i had plans of putting a s/c on mine once i got tired of a measly 310rwhp lol.
and i'm moving to atl and my car wont pass smog tests with a loud *** exhaust and long tubes let alone i could use the extra money from not having a $450/mo car payment and ultimately i want a 03-04 m45 now.
Old Aug 24, 2011 | 12:21 PM
  #491
Fixxxercask
I would assume so because there are a lot of guys on here pushing 400whp on stock rods that are FI. 400whp is quite a bit more than stock. I wouldn't say 450-500 though.
Old Aug 24, 2011 | 02:01 PM
  #492
Zazz93's Avatar
Zazz93
As for the rods being forged, I found this reference from Modified Mag, I believe this was at Sasha's shop.
"Unlike the OEM I-beam rod, which is manufactured by using powdered metal forged together in a cost-saving process called sinter forging, Pauter uses a one-piece conventional forging process."
Read more: http://www.modified.com/tech/sccp_08...#ixzz1VzD50eAW
Old Aug 24, 2011 | 02:11 PM
  #493
mgrotel's Avatar
mgrotel
Hbeam > Ibeam
is the stock crank forged?
Old Aug 24, 2011 | 10:13 PM
  #494
KA24DE's Avatar
KA24DE
Good insurance for what? When is the last time anyone threw bent a rod at stock powerlevels? You and everyone else here is missing the point: you're putting the money in the wrong places. On a non rev, I can understand upgrading the rod bolts and the oil pump, but I would be trying my damnest to also upgrade that crap called an intake plenum and use a REAL header. Cams and valvetrain would be another, and I'd probably only buy from JWT.
You don't need fancy pistons, rods, coil packs, grounding kits, hell, you don't even need headwork, but it's your money. 3 years ago a Maxima guy with .5 liters less and factory parts made almost as much power as some of "built" guys in this forum using that exact formula. So did Sasha.
I'll just wait for someone to come in and tell me how I'm wrong and how they paid 6K for 15whp. ( most of which was gained from swapping camshafts. )
Old Aug 24, 2011 | 10:16 PM
  #495
KA24DE's Avatar
KA24DE
That doesn't make any sense: Your valvetrain choice will not have an effect on your rods. RPM will, but most cams combined with the crappy intake manifold don't make much power beyond 6500-7000RPM range, why would you need to rev out much higher?
Old Aug 25, 2011 | 06:43 AM
  #496
mgrotel's Avatar
mgrotel
pistons are replaced to get more compression, and im not going for "stock" power levels, im using other power adders so forged was a no brainer. in fact, weak internals is the reason im building in the first place
Old Aug 25, 2011 | 06:56 AM
  #497
e30cabrio's Avatar
e30cabrio
First allow me to say, this is a build thread not a thread on the efficacy of or merits in the use of upgraded components.
Second you say you don't care, it's our money yada yada yada yet seem pretty invested in getting the point across that it is wasteful. After the second long winded post that assertion went bye bye.
Third, all of these builds are increasing displacement, that requires non oem pistons. Pistons require certain rods to go with them and the crank being used. In the case of my stroker I needed to go with the parts that work with my 88mm crank, those parts were specced by Brian Crower as designed when they made the crank. As far as a person just increasing the bore, I think while the motor is apart if you are increasing the potential of the motor it makes sense to upgrade the rods, apparently many agree as I have yet to see a build that did not "waste" (your term) the 4-500 on them (a pittance btw percentally in the scheme of an expensive build like these)
IMHO you have made your point ad nauseum and I for one would appreciate it if you would stop unless you have a constructive point to make.
Old Aug 25, 2011 | 07:15 AM
  #498
mgrotel's Avatar
mgrotel
i see your point, but lets break this down...
rod bolts - yes i agree, but for a couple hundred more i can have Hbeam rods with arp bolts.
oil pump - agree, needs to be replaced
plenum - i remember a shootout somewhere and a worked lower and spacer outperformed everything else. However, a different plen is not tough to change out later. so i guess i agree it needs to be addressed, and i disagree that the stock is worthless.
headers - agree, needs to be replaced
cams - agree, needs to be replaced
valvetrain - agree needs to be replaced
pistons - disagree, needed for compression bump and to fit the machined cylinders
rods - disagree, like stated earlier, couple hundred more and you have brand new Hbeam rods
coil packs - agree, stock is fine
grounding kit - agree, doesnt help
headwork - idk, debatable
overall, we agree most of the time
Old Aug 25, 2011 | 08:19 AM
  #499
KA24DE's Avatar
KA24DE
valvetrain - agree needs to be replaced <---Only if the cam maker advises as such. Running strong springs could lead to more wear (and less power) on cams that don't need it.
pistons - disagree, needed for compression bump and to fit the machined cylinders <---The compression bump itself it's going to do much, but yes, you will lose a little compression with bigger camshafts.
rods - disagree, like stated earlier, couple hundred more and you have brand new Hbeam rods <----not necessary, but I understand the reasoning.
headwork - idk, debatable <---not really. You choke point is the intake manifold, not so much the head.
Tell you what, find me a dyno where higher compression pistons made power on pump gas, and I'll shut my mouth. Of course with a stroker kit you need to change out the crank, rods and pistons, but in a normal build I wouldn't have bothered, especially if I had started out with a Revup motor.
Old Aug 25, 2011 | 08:25 AM
  #500
e30cabrio's Avatar
e30cabrio
This thread we are in now and here:
https://my350z.com/forum/na-builds/2...o-nuts-42.html
And I know there are more.
BTW both of these examples are non revup.
