Should I go to a 1 step colder spark plug?
Old Aug 9, 2011 | 02:27 PM
  #41
mgrotel's Avatar
mgrotel
Originally Posted by Classy
lol, look how far this thread went from 1 step colder spark plugs, lol
ah shoot, im sorry man. i can start a new thread. it did get way off topic and that is prob mostly my fault, sorry
Old Aug 9, 2011 | 02:40 PM
  #42
Zazz93's Avatar
Zazz93
Sure, here is a page with a link to a couple of different meters as well they give a brief overview of what engines normally push.
http://www.aa1car.com/library/engine_blowby.htm
Old Aug 9, 2011 | 02:47 PM
  #43
Zazz93's Avatar
Zazz93
Oh yeah, sorry for the thread jack. BTW I've used 1 step colder plugs and aside from what seemed to be lower performance (idle and drivability issues attributed to fouling), I had to take them out due to random misfires. After that, random misfires ended.
Old Aug 9, 2011 | 02:58 PM
  #44
mgrotel's Avatar
mgrotel
ive had 1 step colder in for a while, but only because i have a 100 shot on the car
Old Aug 9, 2011 | 04:02 PM
  #45
Classy's Avatar
Classy
I don't care, this thread was dead and got some good info about stuff out there
Old Aug 10, 2011 | 05:29 PM
  #46
the_coupe's Avatar
the_coupe
im on oem plugs. i wouldnt much worry bout running anything else unless you're boosted. unless you care to do a dyno with the factory plugs then with colder plugs to see if there is a difference in power.
Old Aug 11, 2011 | 07:16 AM
  #47
Zazz93's Avatar
Zazz93
Don't forget the when you run a step cooler your actually turning the "punch" of the plug down (a tradeoff for cooler temps) so the only way you will likely see higher figures is if the old plugs are bad or detonating.
Old Aug 11, 2011 | 08:10 AM
  #48
mgrotel's Avatar
mgrotel
so colder plugs are supposed to run cooler? i never really understood how that worked
Old Aug 11, 2011 | 08:35 AM
  #49
Zazz93's Avatar
Zazz93
Quoted from Car Craft Magazine.
Heat Range
Controlling the operating temperature of the plugs firing tip is the single most important factor in spark plug design. Heat range is the relative temperature of the spark plug's core nose, and it is determined by the length and diameter of the insulator tip, as well as the ability of the plug to transfer heat into the cooling system. A cold plug transfers heat rapidly from its firing end into the cooling system and is used to avoid core nose heat saturation where combustion-chamber or cylinder-head temperatures are relatively high. A hot plug has a slower heat transfer rate and is used to avoid fouling under relatively low chamber or head temperatures. Whats confusing is that a hotter (higher performance level) engine requires a colder plug because more power equals higher cylinder temperatures.
Read more: http://www.carcraft.com/techarticles...#ixzz1Ujouf0CY
A cold plug (right) has a shorter insulator tip that helps prevent tip overheating and pre-ignition in high-speed engines. A hot plug (left) has a long insulator tip; it holds more heat and tends to burn off deposits.
Read more: http://www.carcraft.com/techarticles...#ixzz1UjpsoXQI
What's not mentioned here is the fact if the colder plug is too cold its more likely to foul under low demand type situations/use.
Old Aug 11, 2011 | 08:36 AM
  #50
the_coupe's Avatar
the_coupe
to help prevent detonation
Old Aug 11, 2011 | 08:41 AM
  #51
mgrotel's Avatar
mgrotel
ok, maybe i should have been running 2 steps colder. i had pretty bad preignition problems. to the point of melting plugs and the insulators breaking off in the combustion chamber.
Old Aug 11, 2011 | 08:52 AM
  #52
the_coupe's Avatar
the_coupe
i would think just 1 step colder would be good for you since you're spraying. and its all in your tune too
Old Aug 11, 2011 | 09:06 AM
  #53
mgrotel's Avatar
mgrotel
yea, but pulled timing and didnt help, was crazy rich, still melting plugs, should have tried 2 steps colder, who knows
Old Aug 11, 2011 | 09:32 AM
  #54
Zazz93's Avatar
Zazz93
Now that's a time when you want to experiment with colder plugs. Melted electrodes are normally the first step to letting you know your too hot. Almost completely attributed to the NOS (but could be from trying to get too much from a particular setup as well).
Old Aug 11, 2011 | 09:37 AM
  #55
Alberto's Avatar
Alberto
Cranky FI Owner
stock heat range for the OP's setup
Old Aug 11, 2011 | 09:40 AM
  #56
mgrotel's Avatar
mgrotel
it was def 100% from the nit, car ran just fine without spray
Old Aug 11, 2011 | 12:44 PM
  #57
Classy's Avatar
Classy
I am running stock heat range, this post is kinda old, haha I have 2500+ miles on the motor already
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
