my turn
Old Jul 25, 2011 | 05:26 PM
mgrotel's Avatar
mgrotel
Any idea roughly how much HP I might see with better test pipes? I'm willing to give up a few HP to have the resonators and it be quieter
Old Jul 26, 2011 | 12:55 AM
kacz07's Avatar
kacz07
...says the guy with the electronic cutout. With stock mid pipe and muffler, you really shouldn't be too loud at all. I wouldn't sweat it. Keep it as is.
Old Jul 26, 2011 | 04:45 AM
tuko316's Avatar
tuko316
Headgames does extremely good work. Expect those heads to flow in the 330+cfm range.
Kaczyou must be an hor or two away from me. I know we work fairly close by.
Old Jul 26, 2011 | 08:30 AM
mgrotel's Avatar
mgrotel
haha, good point sir. but really, when i say i am willing to sacrifice a few hp to keep things quieter, i mean quiet with the cut out closed and sacrificing a few hp with the cutout open.
basically, the car is going to be loud with the cutout open, thats just fact. but with it open, performance is top priority and how the car sounds is basically last on my priority list. its opposite with the cutout closed, performance is not at the top of my list, but sound is more important.
i dont want to scare my neighbors half to death everytime i start my car, but at the same time, as im tracking around miller motorsports park i could care less how loud and raspy it is, if that makes sense. the cutout was my solution to keeping a quiet, classy sounding car without sacrificing a lot of performance.
but if the megan test pipes will hurt performance quite a bit or will limit where i make peak hp, then i will get something else.
Old Jul 26, 2011 | 08:31 AM
mgrotel's Avatar
mgrotel
i tried finding flow numbers for these heads a while back but came up empty, what do they flow stock?
Old Jul 26, 2011 | 08:59 AM
tuko316's Avatar
tuko316
Iirc they flow btw 270 and 280 on the intake and 220-230 on the exhaust.
Old Jul 26, 2011 | 01:58 PM
mgrotel's Avatar
mgrotel
plan to get new final drive ratio depending on where my peak power is after the tune
Old Jul 26, 2011 | 03:57 PM
mgrotel's Avatar
mgrotel
what do you guys think of these test pipes? think i should get these over the resonated megans that i already have based on what im looking for?
http://www.z1motorsports.com/350_g35...oducts_id=3373
Old Jul 26, 2011 | 05:11 PM
mgrotel's Avatar
mgrotel
what do you guys think of the R2C intakes? considering one because of cams, head work, and flowing exhaust
Old Jul 29, 2011 | 08:21 AM
mgrotel's Avatar
mgrotel
Old Jul 31, 2011 | 09:38 PM
mgrotel's Avatar
mgrotel
So my heads should be here soon, is there a book or reference site that details engine assembly and all torque specs? I'll need something since I've never put a vq together before, thanks
Old Aug 1, 2011 | 07:22 PM
the_coupe's Avatar
the_coupe
no site to download the esm? i can help with what i can.
whats the nismo piece??
Old Aug 1, 2011 | 09:13 PM
mgrotel's Avatar
mgrotel
when you say esm, do you mean the factory service manual? i think i know of a place to get that.
the nismo parts are the R-tune headers with the date stamped on them the day they were made
Old Aug 4, 2011 | 09:39 PM
mgrotel's Avatar
mgrotel
anyone? is the factory service manual the literature i want to throw the heads and timing stuff onto the block?
Old Aug 5, 2011 | 02:22 PM
KA24DE's Avatar
KA24DE
Rubbish.
Old Aug 25, 2011 | 04:55 PM
mgrotel's Avatar
mgrotel
Originally Posted by KA24DE
Rubbish.
damnit man, now you got me all stressing out about finding the best intake manifold for my build. i searched and searched and it seems all i can find is vendors bickering like 2 year olds or just a bunch of differeing opinions. anyone have a recommendation for my build? i was planning to use my worked lower non-rev with a 1/2 inch spacer. but if there is a better option, ill see if i can fit it into my budget. thanks
Old Aug 25, 2011 | 10:21 PM
KA24DE's Avatar
KA24DE
What is there to stess? Replicate the upper manifold by SG, use your worked lower and a good size spacer. That should give you the volume and the flow you need. As far as intakes, I always have recommended long tube type intakes over short ram style.
Old Aug 26, 2011 | 08:41 AM
  #38
denchan350gt's Avatar
denchan350gt
Did you modify the intake piece the lower plenum sits on? I gained almost 15hp in the top end over a 5/16 spacer w/stock non rev plenum from 250 to 264hp. I just added a 1/2 spacer to my ported lower plenum pieces.
Pm me your email I'll send you the dyno sheet this is on a non-rev 5at so gains should be more since you are 6mt. I'm using the stock intake on my G35.
Old Aug 26, 2011 | 09:19 AM
  #39
mgrotel's Avatar
mgrotel
are you talking about the collector on the right in this picture?
the ports are smoothed out and it is gasket matched. and i am also an auto G so should be the same. so, you ported the lower plen too? im guessing that is where you got most of your gain from. ill send a pm
Old Aug 26, 2011 | 09:39 AM
  #40
Zazz93's Avatar
Zazz93
Intakes... this engine's intake system left so much on the table its should almost be embarassing to the system's designers. In year over year versions they got substantially better, but it left those of us with the Mk 1 versions looking for more.
I look at it like this,
-Easy and cheap good performer, Basic DE lower (mod or unmodified) + 5/16 or 1/2 spacer
-Reasonable priced and possibly best and easiest bolt up overall performance, MREV2 with spacer
-Best top end, unsure, the mod'ed upper intake on the SG Motorsports car shows the Rev-up plenum can make more power on top than most others, but will likely have lower under the curve numbers.
