Best valve springs and what else is needed
Old Mar 5, 2012 | 06:44 AM
Exo27's Avatar
Exo27
Default Best valve springs and what else is needed
I have recently purchased some kelford stage 2 cams. I also have other upgrades such and the mrev2 lower plenum on the way, full exhaust x-pipe custom built, lightened flywheel and race clutch, pop charger and plenum spacer.
My question is what else do I need to get the most out of my motor to go with the cams such as valve springs and where can I find the best price. Also what ecu flash or ecu replacement would you all recommend. Thanks for all input
Old Mar 6, 2012 | 02:32 AM
snobes's Avatar
snobes
Does your exhaust include a set of headers?
Because that would be the next logical upgrade.
As for tune, use the Osiris software
Old Mar 26, 2012 | 05:20 PM
Exo27's Avatar
Exo27
I have a set or nismo r tune headers I will be installing also just purchased an osiris tuner.
Old Mar 27, 2012 | 09:32 AM
Torgus's Avatar
Torgus
how high do you want to rev?
Old Mar 29, 2012 | 03:28 AM
Exo27's Avatar
Exo27
I would like to rev to at least 7500 on the stock bottom end safely. Also looking for any other suggestions to add power to my current set up till I go forced induction later this year or early next year
Old Apr 18, 2012 | 09:17 AM
PhoenixBazoli's Avatar
PhoenixBazoli
what duration/lift are these kelfords?
Old Apr 18, 2012 | 06:15 PM
kacz07's Avatar
kacz07
You need at least JWT valve springs and shims, but look for compatible kelford spring options. Not sure if they make them, so default goes to JWT.
Old Apr 20, 2012 | 06:25 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Not likely to reliably happen on a non revup engine without at least doing rod bolts (nightmare of a job), a new oil pump and a different plenum
Kelford has a totally separate set of cams they offer for forced induction use
Not sure if I'd chance using that high a lift a cam or that high a duration with NISMO headers. They will want something longer and with a wider collector. Also may run into piston clearance issues.
There are no best springs. Springs come in different tensions and designs for different types of useage. The best ones are the lightest weight, least stiff ones that will deal with the lift your cams have. That determination really should be made by your engine builder, which is who I'd suggest asking before you purchase any other parts, as what you have already may not all work well together
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
dcains
Nov 11, 2015 11:36 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Brantwilliams13
Sep 16, 2015 05:03 AM
