Canadian NA Rev-Up Build
Old May 27, 2012 | 05:04 PM
The_Dr's Avatar
The_Dr
Default Canadian NA Rev-Up Build
So awhile back I noticed engine was burning oil. I kind of expecting this since it was a revup and I knew it was bound to happen. I tired to put it off as long as i could. Until this past fall it was time to pull the trigger. this was not a easy task as there are not many machine shops in my area closest one was a 4 hour drive
Here is the problem related to the TSB for the rev up the oil ring ceases and it cant scrape the oil off the cylinder wall:
Pic 1
Pic 2
Here is the baby in question:
Pic 1
Pic 2
Picked up the motor last friday. Awsome work done by Gord Bush Performance
Pic 1
I initially was going to go with SG long tube headers but the problem is now i have to go for emissions test and I cant spend 9 hours swapping out the heads for standard ones with OEM cats to pass emission tests. So i decided at the last min to go Crawford headers. I also had some old Crawford cats laying around and i will cut out the old cat and put a resonator in.
I'm gonna stick with the rev up plenum for now. did some work on the upper plenum. I probably wont get any gains but it looks cleaner. Ideally I would love to get ITBs, but i cant justify the price. Or somehow mod a HR intake to let the engine breath more, but for now I don't know how to work around the MAF readings, but I'm sure ill find an answer out there since someone has already bypassed it for ITB setup. Also how to get multiple throttle bodies working together. Im sure the answer is out there just gotta dig deeper.
Wish I had more pics but the machine shop was too far away to get pics on progress.
Back home on the stand
Partially assembled
Closer..
Upper Plenum work
Car goes in the shop June 4th. Then the painful task of finding a tuner that's not hours away. But if i had to do it all over I'd drop in a HR and buy the harness adapter from Z fever, but its a little too late now oh well.
Build list:
Stock 2005 Factory airbox (revup) w/ high flow filter from K&N
Z-tube
MD 5/16th spacer
JWT C8R Camshafts
JWT Springs
JWT Clutch and fly wheel
Removed extra idler pulley
Ati Crank Pully
Crawford headers
Custom Test pipe with resonator
HR Y Pipe off an 2009 350Z
HR Head Gaskets
CP 96mm 11.5:1 Pistons .020mm overbore
Eagle H-beam rods
ARP Head Studs
ARP Main Stud kit
OEM Trust Washers
OEM Main Bearings
OEM Rod Bearings
Engine Gasket Kit
Ported Intake and Exhaust on heads
New oil and water pump
There is more but that's just the motor.
Old May 28, 2012 | 09:39 AM
thisishk350's Avatar
thisishk350
nice to see someone doing an NA "build" that isn't just a few bolt-ons, lol Nice work OP definitely in for results! 11.5:1 will be pretty gnarly, I would love to see an ITB setup on a G as well!
Old May 28, 2012 | 09:53 AM
kacz07's Avatar
kacz07
Bore out the pistons more than .020mm and got with 12:1. You will gain from that. I would do that if I had the option to redo my pistons.
Old May 28, 2012 | 11:22 AM
thisishk350
Guess you missed the part where OP already picked up the motor? lol its already done man
Old May 28, 2012 | 11:57 AM
kacz07's Avatar
kacz07
Thought about it, but didn't go back and check. Just a word of advice to the viewers then.
Old May 28, 2012 | 12:35 PM
mw9's Avatar
mw9
in for updates
Old May 28, 2012 | 05:58 PM
The_Dr's Avatar
The_Dr
Like i said if i had to redo it id get a HR and get a harness from Z Fever. Just a point of curiosity but 12:1 What kind of octane would that require and also would stock injectors suffice? As for results that will be a while gotta locate a tuner that can do a same day tune there are not many options for a up rev tune around here. and by not many i mean 2 both hours away
Old May 28, 2012 | 07:07 PM
The_Dr's Avatar
The_Dr
Also to add anyone know how jenvey are able to get multiple throttle bodies working on off the factory plug/sensor?
Old May 28, 2012 | 07:14 PM
kacz07's Avatar
kacz07
ProEFI, probably Haltech, Motec. It's big money.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
