NATS removed still no power or Signal to ECU
Old Aug 13, 2012 | 12:58 PM
350zJDMnismo27's Avatar
350zJDMnismo27
Angry NATS removed still no power or Signal to ECU
alright so her it goes. I just did a 06 vq35de hr swap in my 03 z which had a vq35de in before. I swapped out the ECU and harness to a vq35de hr and then got the NATS system removed. Removed all my OEM gauges as well. Went to go to start the car and I got nothing there were 2 grounds that I had cut off for the headlights and airbag and crash sensor harness. Grounded those wires and now my fuel pump will come on from ignition but nothing else. I ran meter on the power pins for ecu and they are not getting power any ideas? But fuel and bcm are turning on.
Old Aug 14, 2012 | 10:57 AM
jwttz's Avatar
jwttz
Your answer is in my thread about this same swap. The 06 swap is not an hr as well it's a rev up.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
