210 hp stock? 2003
Well, guys, this could be in the wrong place, if so please move it. Anyhow, last night, I slapped my car on the dyno for the first time. My car is all stock. I wanted to dyno it before my mods so I can see what kind of power I made. So, it was a dynojet, it was 83 degrees, and the humidity gauge was reading 76.6. Not exactly the best conditions, but my hard pull through fourth gear resulted in 210 hp at 6k Rpm's. I was expecting more.. Does it sound on par to you?
You only did one pull on the dyno? Sounds like it was probably too hot for the dyno pull. BTW, as far as I remember, the pull should have been done in 5th gear.
Good idea on getting a baseline, though.
1074 horsepower at 6600 Rpm's!!!!
Hitting the rev limited messed everything up.. Lol but I have the paper that shows it
It's been a loooong time since I've done a dyno on my car, but I believe 4th gear (so to speak) is for auto's and 5th gear is for the manuals. Someone correct me if I'm wrong, though.
The heat and humidity definitely affected your numbers. There's at least a 20% loss of power through the drivetrain to the wheels when calculating HP. You should have seen numbers in the 230's. Maybe those numbers you got could be correct.
The first time I dyno'd the Z, it was below freezing outside and my car was fairly new. I remember seeing ~242whp on the graph. I was pretty stoked about that.
It does sound low…I agree with Smooth, a stock setup will yield 230 to 240whp.
Whenever I dyno, it seems that the first few pulls are low / lower…so see if you can't get 3, maybe 5 pulls in.
I'll state the obvious, but can I assume your air filter has been changed in the last few months and you have no Check Engine Lights on? how is your fuel economy - part of me thinks you have a bad(or going bad) o2 sensor?
First off, the dyno tech was wrong about fourth gear. Fifth gear is 1:1 and depending on the condition of your VQ, you'll see between 235-245 hp at 6200 PRM. That's easily verifiable by doing just a little research.
If I had an 03, I'd be happy that it ran & took me places. I'm sorry, I just don't get it....
