DE RaceCar Dyno Numbers (Stock Long Block)
Old Mar 1, 2014 | 08:21 AM
03threefiftyz's Avatar
03threefiftyz
Default DE RaceCar Dyno Numbers (Stock Long Block)
*Dyno Sheet will not be provided. I prefer to keep the specifics private from competition. Read into that what you want, but it's how it is.
Motor is a 37k mile DE out of an 04 Auto Convertible. 190psi across the board, very low leak down. Really got lucky with this motor. It is always a crap shoot when you buy a used, unseen motor, but it worked out.
Motor Mods:
Custom intake w/3" MAF
5/16" Motordyne Spacer
UR Crank Pulley
600cc DW Injectors
255lph DW Pump
Tomei V2's
Z1 Test pipes
Motordyne XYZ with resonator (have to have it to make sound restrictions)
Full Titanium w/resonator JIC Exhaust
Runs on E85
Uprev - No compromise tune. Very limited mile race car. Would be borderline and very aggressive for a DD Car.
I have actually run same day on this dyno and a dynojet (SAE) on the same day in years past. Dynojet read about 2.5% higher (in SAE) than the dyno used for this tune.
Results:
296whp/284wtq (figure about 302/290 SAE on a dynojet).
Much stronger than I had expected. I actually ran 108.5mph in the 1/4 making 270whp on the same dyno and at about 150lbs heavier than the car is now several years ago.
Bash away.
Old Mar 1, 2014 | 10:06 AM
jwttz's Avatar
jwttz
Nice! what did you do to the fuel system to make it compatible with e85? Also what db is your car at with that exhaust system?
Old Mar 1, 2014 | 10:09 AM
03threefiftyz
I am 100db at 75' +/- .5db. Just the pump and injectors, but keep an eye on the lines, the E85 is very corrosive.
Old Mar 1, 2014 | 11:01 AM
350z-Na's Avatar
350z-Na
pretty good with stock cams.
Old Mar 2, 2014 | 11:52 AM
waldo36's Avatar
waldo36
Pics/details of custom 3" intake?
Old Mar 2, 2014 | 12:26 PM
Suwaidi's Avatar
Suwaidi
Very impressive, wondering what it would make with bigger cams.
Old Mar 2, 2014 | 12:41 PM
03threefiftyz
Nothing fancy, just a 3" tube, port matched velocity stack (to the 80mm inlet on the maf) and a filter. Probably test a larger TB/Manifold/3.5" Intake setup in a month or so. I think there is another 10-12whp in correct intake set-up.
Can't upgrade cams in the class I run, so have to maximize things on the breathing side. Tentatively planning to move the car to NASA TT3 in 2015, which would mean I can do cams. I would hope to make 325whp with just cams, assuming I can get it up near 308-310whp before the top end stuff.
Old Mar 2, 2014 | 12:57 PM
Suwaidi's Avatar
Suwaidi
Speaking of breathing, have you looked into the process that Z1 has been applying to the VQ37HR/VQ35HR platform? Specifically with the intake runners, have heard people speculating a gain in top end power with minimal sacrifice in mid/low - haven't seen results or much feedback about it though. Referring to the "Intake Plenum Power Mod" they've recently advertised.
mw9's Avatar
mw9
Nice job!
Old Mar 3, 2014 | 04:55 PM
str8dum1's Avatar
str8dum1
E85 is not very corrosive. I doubt you are scared to pour some Everclear or vodka on your hands. But, it is hydrophilic so it attracts water, which is what causes problems...
Methanol is more corrosive.
Old Mar 3, 2014 | 05:34 PM
03threefiftyz
*Very corrosive was overstating things....
Old Mar 24, 2014 | 12:51 PM
Fixxxercask's Avatar
Fixxxercask
Very Nice!
Old Mar 24, 2014 | 03:18 PM
2bad240's Avatar
2bad240
Wish we had e85 here...
Old Mar 25, 2014 | 09:49 AM
KA24DE's Avatar
KA24DE
Nice, but why Tomi cams and not JWT?
Old Mar 25, 2014 | 12:25 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ He's on stock cams. Tomeis are probably headers.
Old Mar 25, 2014 | 12:52 PM
npr350z's Avatar
npr350z
Nice,all that on stock cams and just a auto de! Makes me wanna get a setup for e85!
Old Mar 28, 2014 | 07:38 AM
03threefiftyz
Car is a 6sp, but the motor is out of an auto....not that it matters. I can't upgrade cams in my class, but it I may bump up next year or run Nasa TT3.....or both.
Old May 14, 2014 | 12:31 PM
RedBullRR's Avatar
RedBullRR
Do you have any video's of your Car? Would love to hear the exhaust setup on this Beast.
Old May 25, 2014 | 08:52 PM
RacingBlack350Z's Avatar
RacingBlack350Z
Sorry if this is a bad question, but would it be possible to get even close to these numbers without the e85?
Old May 26, 2014 | 05:02 AM
03threefiftyz
I doubt it. The motor in the car is super strong. The E85 is good for about 12whp/10wtq on the old motor. I still have about 5-8whp that can be gained, but that's about it. I would say about 285-290whp is about it on 93oct, but you have very efficient breathing mods and LOTS of tuning. That tune would probably not be all that safe for DD type stuff either.
