Upper plenum project 75mm Maxima TB
Old Mar 8, 2015 | 08:06 AM
Fixxxercask's Avatar
Fixxxercask
Sub'd.
Good luck with everything! Interested to see how this turns out.
Old Mar 9, 2015 | 11:51 AM
1cockyZ's Avatar
1cockyZ
Old Mar 9, 2015 | 01:07 PM
1cockyZ's Avatar
1cockyZ
Old Mar 9, 2015 | 05:04 PM
DarkZ03's Avatar
DarkZ03
When do you guys start testing on the dyno?
Old Mar 10, 2015 | 05:46 AM
Conway_160's Avatar
Conway_160
How much air flow do you think you will gain by removing those pillars? Also ho much weaker do you think it would be if you removed all 6?
Old Mar 10, 2015 | 06:39 AM
1cockyZ's Avatar
1cockyZ
Stanchions were removed for 2 reasons, to increase plenum volume and airflow around and over the top of the runner. I have no interest in removing all six as the centers offer a lot of support. The goal of this project is to increase airflow to the plenum and then a spacer can be added to tune plenum volume. It has been proven that revup lowers do not benefit from a spacer or show very little gains, but what if the airflow is increased?
Old Mar 10, 2015 | 03:13 PM
1cockyZ's Avatar
1cockyZ
Dyno tentatively scheduled for Thursday afternoon. Will be compared against APS tallboy and Kinetix Velocity. 75mm tb will be used for all tests. Wideband will be used and I am hoping that plenum vacuum can be monitored as well.
Nonrevup lower will used with modified upper and APS upper.
Old Mar 11, 2015 | 03:19 AM
dsm_mikey's Avatar
dsm_mikey
Will definitely be keeping an eye on this one!
-Quick Question...Is the Kinetix V+ Intake manifold (The plastic one) worth trying? Does it have a larger inlet for the throttle body than stock?
-I am looking to run a NWP 75mm Throttle body with my set up. I was considering having the stock upper manifold inlet bored out to make a 77mm passage way...just don't know if there is that much material that can be safely removed without issue...
Thanks!!!
Old Mar 11, 2015 | 09:50 AM
DarkZ03's Avatar
DarkZ03
I have not held the lower in my hand for a few years, but aren't the bolt holes for those 4 pillars drilled all the way though, if so are you going to plug them up?
Old Mar 11, 2015 | 09:52 AM
JoshLarson's Avatar
JoshLarson
Sub'd. Thursday's dyno can't come fast enough.
Old Mar 11, 2015 | 11:40 AM
1cockyZ's Avatar
1cockyZ
Same way APS does or we can weld them shut but that's irreversible.
Old Mar 11, 2015 | 10:53 PM
by15vc's Avatar
by15vc
What size intake tube, maf housing, and filter will you be using?
Old Mar 12, 2015 | 08:54 AM
iideadeyeii's Avatar
iideadeyeii
in, in, in
Old Mar 12, 2015 | 09:18 AM
1cockyZ's Avatar
1cockyZ
3.5" Amsoil filter with internal v stack, 3.5" pipe to 75mm ID maf housing and then into samco tube which is a little over 3" ID. It's on the car and running. Dyno later
Old Mar 12, 2015 | 12:45 PM
isy_nismo's Avatar
isy_nismo
Cool job dude!! Can't wait to see the results..
By the way any of you know anything about this??
Attached Thumbnails Upper plenum project 75mm Maxima TB-1224788636_boiteaaircourse.jpg
Old Mar 12, 2015 | 06:40 PM
waldo36's Avatar
waldo36
Cocky, don't see the spacer installed on there. Also, what size spacer are planning to put on there?
Old Mar 12, 2015 | 07:01 PM
1cockyZ's Avatar
1cockyZ
I tested it without a spacer. I will have the results tomorrow, everything went smooth doing 3 pulls with each manifold and swapping them on the dyno. All pulls in a 2 hour window.
Old Mar 12, 2015 | 09:59 PM
  #38
terrasmak's Avatar
Will you do another dyno with spacer? Then I would much like to see a MAF sensor bigger than 65mm in the mix
Old Mar 12, 2015 | 10:32 PM
  #39
DarkZ03's Avatar
DarkZ03
Can the stock ECU run a MAF housing that big?
Old Mar 13, 2015 | 09:41 AM
  #40
JoshLarson's Avatar
JoshLarson
Don't toy with my heart, man! Post the dynos!
(But seriously, I am quite interested to see what you find).
