Thoughts on this HP gain?
Old Apr 15, 2021 | 07:24 PM
Robek's Avatar
Robek
Default Thoughts on this HP gain?
So, have me an 2003 350z. The venerable VQ35DE!
Have just installed headers, cat deletes, and exhaust, replaced the intake tube with a better flowing one, replaced the 03 air box with the 06 (to get the velocity stack), plenum spacer and a tune.
Just put down 251 whp on a mainline dyno.
That's peak.
There's definitely been a steady increase in power and torque across the whole range.
That sounds about right, but obviously unremarkable.
Should I be underwhelmed or happy enough with this figure.
Old Apr 15, 2021 | 08:00 PM
DarkZ03's Avatar
DarkZ03
I'd say it's a little low but dyno plays a part, as well as location and header choice, a lot of them lose power.
Old Apr 15, 2021 | 08:05 PM
bealljk's Avatar
bealljk
I’d say that’s about right ...
back in the day I did 246hp with some bolt-ons
but as Dark said, many variables to consider...
Old Apr 23, 2021 | 06:15 AM
itsLeon's Avatar
itsLeon
All dyno's are different so you can't really compare dyno results. The only thing that matter is if there is a difference in HP before you put all those parts on? So did you do a dyno run with your complete stock car?
3z5x06rz
Sep 2, 2012 05:18 PM
vTxSpikeZ
Tuning
13
May 28, 2010 07:35 AM
SuperMiguel
Apr 8, 2009 04:35 AM
Nihilation
May 28, 2007 07:59 PM
Beeker
Tuning
25
Jul 15, 2006 08:09 AM
