Intake restriction on my freshly built NA engine ?
Old Aug 16, 2022 | 07:55 AM
  #41
msitpro's Avatar
msitpro
Originally Posted by RobPhoboS
My car is on the stock (not flow tested) injectors,
I still have my original plenum, and had been considering doing a similar thing to Sasha (widen/smooth the neck), and an extra large spacer to see if that makes a difference over the Velocity.
I had considered trying to get the HR plenum and dual TB's to work as well (not sure it's possible with my Link G4+ and the Link E-throttle G4 device), although they have squared runners iirc.
And yep, lastly, it would be ITB's
Ah - Injectors by my calculations at stock fuel pressure flow 330cc/min .... that's 15kg/h fuel flow (0.33 * 0.76kg - weight of petrol), times by 6 cyls - 90kg/h max flow, which at 12.5:1 AFR at 326bhp (246g/sec at stoich) nets you about 70.8kg/h fuel flow required. So you're well within injector duty max.
Regarding the plenum. I believe high plenum volume helps you at low and mid range, low velocity of air. A good example of this is if you watch the video on youtube of the Aussie guy that now owns a GT300 Z33 with it's huge plenum. Nismo did this to give them a small boost of mid range torque coming out of corners. When that volume of air ran out, they were then going through restrictors that limited them to 300whp peak.
I think the big thing is getting smooth direct flow, rather than volume for top end. This is very difficult in the confines of the Z's engine bay/bonnet. If you went as far as getting a dry sump and used the height difference to drop the engine down (like the GT300 Z) then it might be a lot easier!
itsLeon
NA Builds
63
May 26, 2021 07:30 AM
Michael Zosa
NA Builds
33
Oct 10, 2019 07:21 AM
BohnsZ
NA Builds
17
Jan 29, 2016 08:51 AM
punish_her
Pacific
98
Dec 27, 2006 05:19 PM
