Fuel Tank Pressure Sensor
Old Apr 8, 2015 | 04:09 PM
pvdao's Avatar
pvdao
Default Fuel Tank Pressure Sensor
Hi, I have a 2005 Z and was told (by autozone) that I need a new fuel tank pressure sensor. It looks like this (below). My question is, where is this sensor located? I assume it's somewhere near the gas tank right? I've also searched all over google and this forum, and no success.
Thanks
Amazon.com: Wells SU6854 Fuel Tank Pressure Sensor: Automotive Amazon.com: Wells SU6854 Fuel Tank Pressure Sensor: Automotive
Old Apr 8, 2015 | 04:32 PM
bealljk's Avatar
bealljk
Just curious...why did they tell you needed this part?
Old Apr 8, 2015 | 05:20 PM
pvdao's Avatar
pvdao
I had a service engine light. Code came up and they recommend replacing this sensor. Otherwise the car runs fine and no gas gauge malfunction whatsoever
I had the service engine light resetted but it'll probably come back and w it back, I will not pass nj inspection.
Old Apr 9, 2015 | 06:02 PM
bealljk's Avatar
bealljk
what code was thrown? I'm by far no expert but does the gas tank have a 'pressure sensor' ...
Old Apr 10, 2015 | 02:58 AM
pvdao's Avatar
pvdao
There were like 8 different codes and autozone advise me that the sensor needs replacement. I figure out that the fuel tank sensor is also called as the EVAP control system pressure sensor. It is located underneath the engine (see pic).
Also told that the sensor does not affect engine performance bc it is used mostly for gas emission purpose. Hence I may be polluting more than a fair share
Old Apr 10, 2015 | 07:31 PM
bealljk's Avatar
bealljk
Thats not the engine - that's passenger side rear of the car...pretty easy to get to though...it's starting to make a little more sense. Can you list the what codes are being thrown?
Old Dec 3, 2022 | 11:31 AM
Sebagonz's Avatar
Sebagonz
Hello I have code p0451 and I’m thinking I made sure gas cap was closed right, should I change the Evap pressure sensor or should I change the gass cap?. I have a 2004 350z enthusiast with 136k miles
Old Dec 3, 2022 | 03:45 PM
bealljk's Avatar
bealljk
I would inspect the EVAP hoses and EVAP sensor wiring (as best you can) around the engine bay, (safely) under the car, an the evap canister (in the rear of the car) and look for obvious damaged hose and if you dont see anything blaring than replace the sensor.
Old Dec 3, 2022 | 03:47 PM
Sebagonz's Avatar
Sebagonz
Thank you will be checking it tomorrow and if I don’t see anything I’ll change the sensor next weekend and I’ll get back to this to let y’all know if it fixed ir
apex locator
Jul 23, 2021 02:27 AM
