Any tips on what to replace on my 350z 04 for maintenance.
Old May 1, 2019 | 12:53 AM
350Z 04's Avatar
350Z 04
Default Any tips on what to replace on my 350z 04 for maintenance.
Hey guys I just got my 350z from my uncle 60,000miles he had this car abandon for like 1 or 2 years do you know what should I change to the car engine for maintenance I just order a variable valve timing selenoid apparently it was malfunctioning also 4 oxygen sensors for replace do you know what else should I change to the car. Ps. Oil oil filter and air filter were replace already FYI
Old May 1, 2019 | 02:07 AM
travlee's Avatar
travlee
Master
trans and diff fluid, coolant wouldnt hurt, check belts...
Old May 1, 2019 | 11:24 AM
dkmura's Avatar
dkmura
General & DIY Moderator
While you've got the car up in the air, you might as well bleed all four corners with fresh DOT 4 brake fluid until the brake master is full of the fresh stuff. Also, check the condition of the brake pads and discs while you're at it.
Old May 1, 2019 | 06:22 PM
350Z 04's Avatar
350Z 04
All fluids were change belt is new trans oil 100% they check all that on Nappa the only thing I got is engine light with slip lights are on so I ordered variable valve timing selenoid for exchange with the camshaft sensor to see if that fix the lights, thank you for the support guys! Btw is my car a DE or a HR? I have no idea how to tell the difference. 350z manual 2004 (any idea on how to tell the difference guys?)
Old May 2, 2019 | 01:13 AM
travlee's Avatar
travlee
Master
De.... hr was 07-08 (and 09 verts)
scrillasherv
Apr 25, 2021 01:29 AM
Doba
Nov 20, 2019 05:21 AM
geosar
Sep 29, 2012 09:10 PM
KingofScion
350Z Roadster
Apr 15, 2004 04:39 PM
