350z lower plenum torque specs
Old May 21, 2021 | 04:57 PM
sarcasticsara's Avatar
sarcasticsara
Default 350z lower plenum torque specs
The bolts in my lower plenum keep snapping. I’ve looked it up a million times and everywhere I’ve seen says between 40 and 60 inch lbs and I can’t even get past 20. I’ve even gone so far as to order brand new ones from concept z performance and they still break and get stuck in the manifold right before I hit 20 inch lbs. Has anyone else had a problem like this? And if so, how did you fix it?
Old May 21, 2021 | 07:57 PM
DarkZ03's Avatar
DarkZ03
Are you sure you aren't using FT-LBS instead of IN-LBS?
Old May 21, 2021 | 09:02 PM
sarcasticsara
Positive lol
Old May 26, 2021 | 02:28 PM
Heel Til I Die's Avatar
Heel Til I Die
Maybe your torque wrench is no good?
Below are the specs from the FSM:
Old May 26, 2021 | 02:35 PM
sarcasticsara
nah, I ended up torquing a few other things on my z that needed to be torqued to specs and it worked just fine, idk what was wrong w the plenum bolts, maybe they were just bad quality ig. I just ended up tightening the ones in the plenum as much as I could without torquing them to specs and they’re holding up fine so far lol
Old May 27, 2021 | 08:04 AM
jhc's Avatar
jhc
General & Tech Moderator
The specs are correct for OEM bolts provided you aren't trying to use a ft lb torque wrench and dividing by 12. Gl!
Old Mar 5, 2024 | 07:40 PM
Slycab's Avatar
Slycab
Are the torque specs the same for the lower plenum like the upper one?
MurphysZ
Aug 15, 2024 10:50 PM
jonahlw
Sep 24, 2007 08:21 PM
Mazinger Z
May 26, 2007 01:15 PM
aleok
Jun 4, 2006 02:49 PM
NiSmO21z
Nov 11, 2005 09:35 AM
