What makes the '07 Nismo the "Best Handling Z Ever"
Old Sep 10, 2007 | 03:24 PM
kaizenro1's Avatar
kaizenro1
Originally Posted by !prjctmax!
Sorry for being a but what do the dampeners exactly do?
Keeps the car wet, hence dampener. Not completely drenched though. If you want that, get drencheners.
Old Sep 10, 2007 | 03:33 PM
TSG-Z's Avatar
TSG-Z
I had a set of Drencheners, cost me a pretty penny!
Old Sep 10, 2007 | 07:35 PM
!prjctmax!'s Avatar
!prjctmax!
Just because I'm a n00b, doesn't mean I'm a , even though I just said I was!
Old Sep 10, 2007 | 08:59 PM
!prjctmax!'s Avatar
!prjctmax!
Originally Posted by MC
they are placed on key frame points to stiffen it up and reduce body vibration. that makes for sharper turn in capabilities and better response
thank you!
Can this type of "mod" be done on any car with the right size dampener and mounting locations? How beneficial/noticable is this though?
Old Sep 10, 2007 | 10:20 PM
kaizenro1's Avatar
kaizenro1
Good sport you are!
You got a free bump! Here's another!
Old Sep 10, 2007 | 10:22 PM
kaizenro1's Avatar
kaizenro1
Uhhhh, ya know ugly pennies spend just as well as pretty pennies. And they have great personalities too.
Old Sep 17, 2007 | 08:54 AM
Gator's Avatar
Gator
Interesting. I've seen a lot of discussion lately about chassis stiffening with some aftermarket companies selling braces that go under the car to lessen chassis movement. Super Street is doing a project STI and used some of these pieces from Carbling. They said the one that made the biggest difference was one that mounted behind the front seats between the two front seatbelt floor mounts. That's a similar position to the rear Yamaha damper on the Nismo Z. It looks like the two Yamaha dampers could be retro-fitted. I am sure the Nismo guys know what they're doing but that extra strut bar in the front? I wonder how much difference it really makes? Must do something for them to spend the money to put it on every Nismo Z.
Also, I thought these were not done in the Nissan factory but were done by another company Nissan contracts. Sort of like a Calloway Vette or something like that. Anybody know? Just curious.
Old Sep 17, 2007 | 09:23 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yea the companys name is Altech.
Old Sep 17, 2007 | 09:25 AM
jmark's Avatar
jmark
Autech. The Sports Car International article I started a thread about says the Yamaha dampers keep the car from acting like a tuning fork once all the stiffening is done. It is F1 technology.
Old Sep 17, 2007 | 09:30 AM
azula's Avatar
azula
Originally Posted by SOLO-350Z
Nothing to do with the engine at all. The car has specially tuned suspension, that you can't just buy. It has stiffer sways, it has seam welds on the unibody instead of spot welds, it has torsion dampers front and rear, etc. It helps if you do a search.
there is nothing that money can't buy, just most things ppl can't afford, lol
Old Sep 17, 2007 | 10:37 AM
mavtais's Avatar
mavtais
That was my guess.
Old Sep 25, 2007 | 05:41 PM
supmahBRUDDah's Avatar
supmahBRUDDah
Just a question as im no engineer, but since that's a four door aren't the dynamics of that positioning for the damper different? i would think the dynamics would be much different considering the CoG. And i would think that the necessity of the front damper is only that - a necessity- as i would trust a group like Nismo even their contracted help
Old Sep 26, 2007 | 03:02 PM
hardrock905's Avatar
hardrock905
Originally Posted by SuperFLY
not that im an expert but iirc the engine is mounted higher (hense the bulge) to give the car a more central centre of gravity and improve its poise/stability improving handling.
i dont 'think' there were any suspension changes, i could be wrong.
Unf'inbelievable.
And "a more central centre", lol.
A high center of gravity causes body roll and less control among other things. This is why people lower their cars for better handling, not eqip them with lift kits.
Old Oct 8, 2008 | 10:35 AM
chrisl113's Avatar
chrisl113
hey i dug this up to save from a new thread... im looking for more info on the secondary strut bar and the yamaha dampeners? im suprised i havent been able to find more discussions on these two? maybe i suck! either way, for an 07 base dd, would there be any benefit for transplanting these if they could be? or are these little minute things that help in high stress/track situations? thanks!!!
Old Oct 8, 2008 | 11:34 AM
Lento's Avatar
Lento
I believe I read that the suspension is about 35% stiffer than a normal Z
Old Oct 8, 2008 | 06:51 PM
mavtais's Avatar
mavtais
A few posts earlier, we discussed this.
Only if your car is stitch-welded and as stiff as the Autech body. So, the answer is most-likely "no" on the transplant, unless you stitch-weld.
Old Oct 8, 2008 | 08:44 PM
  #38
chrisl113's Avatar
chrisl113
^ ok thanks, but as far as the secondary strut bar?? or was that part of the "stitch-weld" answer? cheers
350Z_Al
Oct 29, 2020 07:44 PM
