Driving hard!?
Old Apr 11, 2008 | 12:33 PM
Lento's Avatar
Lento
Originally Posted by Manu
5K rpm to start is definitely abuse. You need at least 5800 rpm
Haha I hope your going to ante up the money for a new clutch after he takes you up on that advice
Old Apr 11, 2008 | 01:21 PM
Manu's Avatar
Manu
No
My 2 cents, if you want to make smoother upshifts.
When shifting up, instead of doing this.
1)Release gas pedal
2)Depress clutch pedal
3)Change gear
4)Release clutch pedal
5)Depress gas pedal
Do This :
1)Depress clutch pedal
2)Release gas pedal
3)Change gear
4)Depress gas pedal
5)Release clutch pedal
The very moment you take your foot off the gas, you are engine braking. If you clutch in before you lift off the gas pedal, you avoid the jerk created by the sudden engine braking.
When you Release the clutch pedal, again, you do not want to release into an engine that is braking, a small amount of gas will make the clutch engagement much smoother.
Hope this helps a bit. Cheers !
Old Apr 12, 2008 | 07:12 AM
Lento's Avatar
Lento
Yup I completely agree with you. I tested it out last night and it makes the shifts alot smoother when you keep the revs up when shifting like you said.
Thanks
Old Apr 12, 2008 | 04:11 PM
chris8262350z's Avatar
chris8262350z
that happend to me at the track, its because ur flywheel is spinning so fast that when you release the clutch, the presure plate doesnt have enough pressure to hold the disk to the fly wheel so it just free revs and the clutch stays to the floor
Old Apr 12, 2008 | 04:13 PM
chris8262350z
that reply was for ibsystems
Obadabot
Jun 18, 2023 11:31 PM
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
