Had to replace a tire!!!
Old Aug 1, 2008 | 08:21 PM
BluZee's Avatar
BluZee
Default Had to replace a tire!!!
Leaving work on Wednesday night my low tire light comes on. Everything looks good so when I get to work on Thursday I take it to the service department to get checked and the left rear is about 5 psi lower than the rest. I take a closer look and I could just barely see a nail sticking out of the tire just barely into the sidewall! F*ck!! So the parts department overnights a tire for me that is $280! This is all great after only have the car for a little over three months now. Already had the freak accident with the hood.
The good news is that I took the tire to the wheel shop that I always use and they mounted and balanced it perfectly with no damage. The wheel didnt even look like it had been touched when they were done. I know some others havent had such good luck. So atleast that part turned out ok.
Old Aug 2, 2008 | 10:02 AM
VENOMSZ's Avatar
VENOMSZ
Which tire was it?
I've had the same problem with my 06 Z,
and my 08 Nismo...both driver's rear.
It is a strange phenomena, alot of people having
this issue with the same exact tire?
Old Aug 2, 2008 | 10:23 AM
Sensi09's Avatar
Sensi09
Works Concepts
How many miles do you have? You should probably replace both tires on that axle.
Old Aug 2, 2008 | 02:26 PM
east1999bt's Avatar
east1999bt
Originally Posted by VENOMSZ
Which tire was it?
i've had 3 nails (all repaired though) in that 1 tire (driver side rear)!?
Old Aug 2, 2008 | 07:49 PM
BluZee's Avatar
BluZee
Only 4000.
Mine was the drive rear also!!
350z82
Oct 1, 2015 06:25 PM
