Springs only for Nismo Z.
Old Dec 16, 2008 | 04:55 PM
IPGDriver's Avatar
IPGDriver
Corporate Whore
Originally Posted by 350z_racer05
thank you captain obvious
Old Dec 18, 2008 | 11:21 AM
jerseystyle's Avatar
jerseystyle
Old Jan 2, 2009 | 08:57 AM
sektor 11's Avatar
sektor 11
Originally Posted by Gsedan35
I'm not out to be mean or anything, but,................
Why would anyone that has a special version of a sports car, that has specific changes done to it to enhance what the car is, install much softer springs just to improve the looks of the car? I mean it toally goes against why you paid extra for the car in the first place.
Nismo Z
*Spring rates 424/576
* according to the factory the car uses springs that are +35% stiffer then oem
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown
You cannot purchase lowering springs for the Nismo Z that will drop the car and be equal or better to the oem springs. If you must lower the car, do so with coilovers, one's that actually stand a chance of being better then the oem springs and shocks.
Eibach 350Z progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z sportline progressive springs 1.2"/1.2"
F: 239/400 R: 257/435
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Cobb tuning linear springs
drop 3/4" - 15/16"
Spring rates 436/535
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Progress Technology progressive springs 1.0”/1.0”
Spring rates in LBS 425/385 (final rates only, softer intial front progressive rate unknown)
Tokico D-spec shock & spring package
350Z - DSK512 - 375f/375r - Linear Springs 1"/1.5"
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” higher
Spring rates in LBS 314/353
Skunk2 350Z progressive springs 1.3”/1”
Spring rate in LBS 238/381 237/395
Swift 350Z linear springs .8”/.6” drop on 350Z, G35 drop will be higher)
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2”/1”
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Nismo T2 350Z Linear springs 1”/1”
Spring rates in LBS 625/700
Vogtland 350z progressive springs 1”/1”
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
Kg/mm springs 350Z DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Kg/mm DRacing progressive springs 1.2”/1.2”
Spring rates in LBS initial/final front 252/454 initial/final rear 252/482 rear
Whiteline 350Z linear springs (control)
Front: Part # 73219,
Spring rate 365 LBS Drop: .8"-1"
Rear: Part # 73220
Spring rate 445LBS Drop: 1"-1.2"
(sold as 2 front springs and 2 rear springs)
www.whiteline.com.au/store/
Espelir 350Z progressive springs 10mm drop F&R
386/515 (softer initial progressive rates are unknown)
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
very informative! thanks!
Old Jan 3, 2009 | 03:29 PM
07Nismo350z's Avatar
07Nismo350z
Since having lowered the Z no such rubbing issues, and the handling is just the same as the Nismo springs. Here's another pic.
Old Feb 5, 2009 | 12:39 PM
white323nismo's Avatar
white323nismo
what kind of springs did you use?
Old Feb 8, 2009 | 08:24 AM
sabelotodo's Avatar
sabelotodo
what about the nismo T2 springs listed as a higher spring rate then the ones on the actual nismo z and a one inch drop like you want
Old Feb 9, 2009 | 03:33 PM
07Nismo350z
Tanabe GF210
Old Feb 10, 2009 | 09:21 AM
supracar's Avatar
supracar
did it change the feeling as far as handling and ride quality?
Are you expecting some sort of educated, intelligent useful response here? Allow me to help - "now it handles like it's on rails" .
Old Feb 10, 2009 | 05:36 PM
0jiggy0's Avatar
0jiggy0
Take a look at those spring rates again. That is incredibly high. Unless you drive only on glass or track the car 95% of the time, I couldnt imagine putting up with that stiff of a ride.
Old Feb 11, 2009 | 08:09 AM
Gsedan35's Avatar
Gsedan35
21%/35% softer springs doesn't equal a improvement. Any perceived improvement is coming courtesy of the bumpstops becoming a secondary spring which it doesn't take too much to figure out is a bad thing. Then again IIRC the op was just after looks.
Old Feb 11, 2009 | 08:12 AM
Gsedan35's Avatar
Gsedan35
Because the oem Nimso shocks cannot deal with springs that stiff. Put the right shock with the T2 springs and ride quality can be tolerable.
Old Feb 14, 2009 | 11:13 AM
FORZWIN's Avatar
FORZWIN
Might not be of interest to you, but have you considered trimming the rear spring mount to get the extra drop you're looking for?
The Rear Spring Mount Mod
Old Feb 14, 2009 | 11:42 AM
Jay2's Avatar
Jay2
I have considered that and contemplating it. I'm happy with how the front looks but wish the rear was at least 1/2" lower. And I know I can get that drop by modding that spring mount.
Old Feb 14, 2009 | 05:47 PM
NISMO_558's Avatar
NISMO_558
damn, I forgot all about that mod.
Old Feb 19, 2009 | 01:36 PM
FORZWIN's Avatar
FORZWIN
That's my plan, I don't have a nismo, but I plan on doing it after I get back from VIR this weekend if you're interested in pictures. It's an 03 so the rear gap isn't so pronounced but still a little more than it should be. I too can live with the front.
Old Mar 11, 2009 | 06:56 AM
eddiebrock71's Avatar
eddiebrock71
Your best bet would be Cobb springs. Almost an inch drop and the spring rates are very close. Other then that no other spring offers the kind of spring rates the nismo has...
Old Mar 12, 2009 | 10:17 AM
Gizmo0803's Avatar
Gizmo0803
Has anyone done the spring mount mod on their nismo Z? I'm just wondering if the change in height will drastically effect the performance of the car. Not to mention, i don't want the nismo shocks to blow out prematurely...
Old Mar 12, 2009 | 05:37 PM
  #38
Jay2's Avatar
Jay2
I've got brand new spring mounts at work waiting to be cut. Plan on getting it done this weekend. A 1/2" would make it look good but after putting my new wheels on, I'm pretty happy with the stock rake/ride height.
Old Mar 12, 2009 | 05:55 PM
  #39
Gizmo0803's Avatar
Gizmo0803
let us know how that turns out...and if there's any problems with the ride quality...
nanotech
Oct 2, 2015 05:02 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
