Cracks in Nismo Splitter/Fascia
Old Mar 21, 2009 | 10:24 AM
bena1916's Avatar
bena1916
Default Cracks in Nismo Splitter/Fascia
So I noticed today that on the front fascia (terminology might not be quite right) that I have cracks forming on both the right and left side. Also, there appears to be something amiss as a small plastic piece (on both sides) seems to be out of place and it looks like it should be tucked inside. This I think is causing the problem.
First picture is just to locate where I'm at on the car.
Cracks in Nismo Splitter/Fascia-dsc_0020.jpg
This one is of the right side.
Cracks in Nismo Splitter/Fascia-dsc_0019.jpg
This one is of the left side.
Cracks in Nismo Splitter/Fascia-dsc_0015.jpg
I did a quick search and didn't find any posts pop up quickly so I was wondering if anyone else had this issue? I have grazed the bottom of the fascia but I don't think that's the issue as there seems to be quite a bit of play/flex in it. Thoughts?
Old Mar 21, 2009 | 12:04 PM
Dozzi94's Avatar
Dozzi94
A bunch of us have some cracks in the bumper man. No worries, really. It's to be expected when your car has a big nose.
Old Mar 21, 2009 | 12:05 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
I got the exact same thing.
Old Mar 21, 2009 | 12:21 PM
VENOMSZ's Avatar
VENOMSZ
It's that protruding metal part that causes it.
If you scrape the front lip it pushes into the metal,
and causes the cracks. My lip was severely damaged by
that same thing at the stealership during an oil change.
The stealership did fix it, amd repaint it for free.
Old Mar 21, 2009 | 05:55 PM
KingBaby's Avatar
KingBaby
Hardest Setting
+1
Old Mar 22, 2009 | 09:08 AM
zstreet86's Avatar
zstreet86
for those of you that have these cracks can you recall scraping the bottom of the lip somewhere along the line?
Old Mar 22, 2009 | 09:10 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Oh hell yeah. My parents have a steep driveway and I scraped the hell out of it when I went to see them.
I park on the street now.
Old Mar 22, 2009 | 10:11 AM
bena1916's Avatar
bena1916
So I guess I'm not going to worry too much about this. However, I'll probably take a dremel tool to it and relieve a little of the material so as to prevent further cracking from the contact problem with that piece in back of it.
Old Mar 22, 2009 | 01:54 PM
KingBaby's Avatar
KingBaby
Hardest Setting
smart, before another scrap sends the tear down an inch...as it did to my car...
Old Mar 23, 2009 | 01:50 AM
godzilah's Avatar
godzilah
got the same problem here too.....
Old Mar 23, 2009 | 03:52 AM
Demonbfg's Avatar
Demonbfg
After you check for cracks, start checking for rust from a bad weld job on the body inside the door close to the round black (stopper or sensor).I've seen it on two 07's so far.
Old Mar 23, 2009 | 04:59 AM
Lento's Avatar
Lento
Same exact thing on my car as well.... gives it character.....
Old Mar 23, 2009 | 05:11 AM
Beka Z's Avatar
Beka Z
mine has the same problem. it's not too bad, but i know it's there!
Old Mar 23, 2009 | 07:15 AM
Lento's Avatar
Lento
I literally have to be right up against it or down on my knees with my head cocked sideways to see it.
No one else will notice it other than you.
Old Mar 23, 2009 | 07:38 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Same problem. You hit some parking stops or something which caused the bumper underparts to raise and cut into the bumper.
My passenger side is the same way sadly.
Attachment 232982
Attachment 232983
Attachment 232984
Old Mar 23, 2009 | 12:58 PM
GalvatronType_R's Avatar
GalvatronType_R
Thanks for the tip, guys. My Nismo is only a month old and I haven't scraped the front end on anything yet. With those cracks, I will be extra careful not to park too near curbs or concrete parking stops.
Old Mar 23, 2009 | 03:19 PM
jerseystyle's Avatar
jerseystyle
Damn, glad I'm not the only one. I hit some rubber off of a Semi trailer on the highway and it did that to my bumper. Really sucks!
Old Mar 24, 2009 | 04:21 AM
frbica's Avatar
frbica
for those who scraped, how hard was it?
i have scraped on driveways and cant find anything wrong, except scratches under the bumper...
the triangle rubber piece on each side are still far away from touching the bumper, and they have a good amount of play...
sorry to see that on your guys rides...
Old Mar 24, 2009 | 09:03 AM
Lento's Avatar
Lento
I've hit mine hard more than a few times on inclines and driveways and such, and I have to say that splitter holds up pretty well underneath.
It usually only scratches the underbody of the splitter, which you cant see anyways.
However if you hit something dead on, like a curb, or a cone or other debris the vibration may crack the side of splitter, by the front wheels
Old Mar 26, 2009 | 03:06 PM
east1999bt's Avatar
east1999bt
Attachment 232982
Attachment 232983
Attachment 232984
i've got what you have on your right side, on the left side of my bumper. exact same "damage"
