one more update...
Old May 18, 2009 | 03:36 PM
Ataru074's Avatar
Ataru074
Default one more update...
Old May 18, 2009 | 04:29 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
looking good
Old May 18, 2009 | 04:34 PM
Waiz's Avatar
Waiz
Nice..
Is that suede?
Old May 18, 2009 | 04:59 PM
Ataru074's Avatar
Ataru074
Originally Posted by Z1 Performance
looking good
perfect fit.. thanks guys for the hub.. as you see... just got it and no SRS errors.
Old May 18, 2009 | 05:00 PM
Ataru074's Avatar
Ataru074
Originally Posted by waizzz
Nice..
Is that suede?
yep!
the classic momo model 07 350mm dia. 70mm deep.
Old May 18, 2009 | 05:07 PM
Simann's Avatar
Simann
LOL, I was looking at a very similar wheel this weekend. Momo Mod 78.
What harness did you use? Works Bell (SRS)
Old May 18, 2009 | 05:12 PM
Z1 Performance
Former Sponsor
happy to help
Old May 18, 2009 | 05:13 PM
Ataru074's Avatar
Ataru074
Originally Posted by Simann
LOL, I was looking at a very similar wheel this weekend. Momo Mod 78 in red suede.
yep.
Old May 18, 2009 | 05:19 PM
Tac-M's Avatar
Tac-M
ah ! sex !
Old May 18, 2009 | 08:24 PM
VENOMSZ's Avatar
VENOMSZ
Looks good.
Old May 18, 2009 | 09:19 PM
KingBaby's Avatar
KingBaby
Hardest Setting
I don't remeber where I saw it, but didn't someone who swapped out there steering wheel...take the cruise control, and rewired it to the opposite side of where the TCS is???
or am I crazy...
Old May 18, 2009 | 11:18 PM
mthreat's Avatar
mthreat
worth half a second per lap, at least
Old May 19, 2009 | 04:29 AM
Ataru074's Avatar
Ataru074
you're kidding but I think it gives a better feeling (the stock was too far for me)
on the other hand this one needs to be driven with gloves.. the rim is quite "thin" and my hands are more like shovels.
Old May 19, 2009 | 04:37 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
looks good man
Old May 19, 2009 | 06:16 AM
Nismo 78's Avatar
Nismo 78
Looks good, did you do the install yourself?
Old May 19, 2009 | 06:54 AM
Ataru074's Avatar
Ataru074
yes... is about 1/2 hour job... 40 minutes top.
1) open the window, put the steering wheel straight (this one isn't necessary, the hub has a "forced" fitting,)
2) disconnect the battery (negative first)
3) purge the capacitors (pump on the brakes)
4) remove the airbag module (2 T30 tamperproof torx on the side of the steering wheel, there are 2 plastic covers to remove with a small flat blade screwdriver)
5) disconnect the airbag connectors (orange and yellow).. lift the black "safety" with a small flat screwdriver and pull them out
6) disconnect the cruise/horn/radio connector (grey) you have to push the lock with the same small flat screwdriver and pull the connector out
7) remove the steering wheel. 19mm hex, you'll need a decent extension for the socket.
8) connect the horn harness (grey connector) comes with the hub
9) connect the airbag resistors (blue one on orange connector, yellow one on yellow connector)
10) remove the hub cover and put the hub in. use the new bolt and the locking washer (they comes with the hub).
11) bring the horn connector inside the hub and fix the airbag ones outside (I used electrical tape and a zip tie)
12) put the hub cover on
13) put the wheel on, the bolts are with the hub
14) connect the horn and put it on.
15) reconnect the battery (positive first, negative last)
16) drive a little and check that the wheel isn't coming loose or have any play.
17) take pictures
18) enjoy
et voila'. done.
again:
tools needed:
small flat head screwdriver
T30 tamper proof torx
19mm socket + extension + ratchet
10mm open wrench for the battery
electrical tape
zip ties
the small hex for the wheel bolts comes with the hub.
the resistors for the airbag are just "plug in"
Old May 19, 2009 | 07:52 AM
Lakeside's Avatar
Lakeside
So you completely eliminated the Cruise control? Not a big deal i guess.
I am so use to having stereo functions on the steering wheel though. When I drive the Frontier I find myself missing those functions on the wheel. lol But it is nice to have a thin rim and more service area to grap onto...
Old May 19, 2009 | 09:52 AM
warmmilk's Avatar
warmmilk
man, i didn't know the swap was so simple. so you could keep that stock steering wheel and swap it out when you go to the track or what not. I'm seriously considering this now...
Old May 19, 2009 | 01:15 PM
Nismo 78's Avatar
Nismo 78
17) take pictures
18) enjoy
et voila'. done.
again:
tools needed:
electrical tape
zip ties
Nice, thanks for the DIY tips. Thinking about doing it myself sometime this summer.
Old May 21, 2009 | 06:07 PM
NA&CH's Avatar
NA&CH
Awesome Man. Nice looking race car
Chriis
Ztouring04
Dec 9, 2012 06:52 PM
PlatinumSR20
May 20, 2011 01:45 PM
djamps
Tuning
Apr 3, 2011 04:02 AM
chuquison
Sep 2, 2008 05:52 PM
