08 Nismo Dyno
Old Dec 15, 2009 | 06:48 AM
4DGS's Avatar
4DGS
Originally Posted by nismomike
Brick, I did not have to trim anything. The inner layer of the intake support comes out with a few screws with the stock intake. The tubes fit in with a good amount of room to move it around. I am not concerned with water because lookin at it, it sits high enough where water will not really reach that spot unles its comin down horizontally by an act of God straight into the grill opening. The only thing i had to do was move the horns further down and screw them into the core support. took like 10 minutes to do that. It was a great experience and it was worth it. Ill put the best pics that I have of it up.
I would still put a hyrdolock on just in case the worst happens you never know...
Good numbers, I want that intake for my G to bad it'll never fit
Old Dec 16, 2009 | 06:17 AM
nismomike's Avatar
nismomike
Where can I find a hydroshield? Will that affect performance? Since it masks the filters? Or is it very "permeable" for the air? If you have a G with the HR engine u can get it!
Old Dec 16, 2009 | 06:32 AM
brick's Avatar
brick
Thanks for the info. Horizontal rain wouldn't be too hard to reproduce on the highway, but I doubt it would be enough to cause any problem. I wonder how hard to would be to make it into a ram air design.
Old Dec 16, 2009 | 06:38 AM
nismomike's Avatar
nismomike
Now you got me thinking....
Old Dec 16, 2009 | 08:39 AM
musubi's Avatar
musubi
From past readings on intakes, I don't think it'll be an issue with water unless submerged. I haven't heard of anyone hydrolocking just from rain.
If you're thinking about putting a bypass valve or a hydrosheild onto the intake, you should've bought the short ram intakes.
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
