Recommended Lowering Springs for Nismo
Old Sep 17, 2010 | 12:13 PM
Row2K's Avatar
Row2K
What about Swift coilover springs ? Whats the inner diameter of the stock springs ?
these:
http://splparts.com/store/product-info.php?pid127.html
Old Sep 17, 2010 | 12:24 PM
terrasmak's Avatar
Originally Posted by KingBaby
stance GR + PRO w/SSD dropped 2 1/2 front all the way in the back
Stillen sways on stiffest setting
rear tie bar
equals grip machine
Actually slip machine unless you on sticky and really wide R comp tires.
Old Sep 17, 2010 | 05:13 PM
KingBaby's Avatar
KingBaby
Hardest Setting
at high speed....yes
Old Sep 19, 2010 | 07:25 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
these:
those need the spl midlink to work
Old Sep 19, 2010 | 09:41 AM
Row2K's Avatar
Row2K
i'm not concerned about the rear as I can always just cut the spring mount, I'm wondering if a slightly shorter spring of the same stiffness (9kg would b about it IIRC) could be used on the stock FRONT damper.
Old Sep 20, 2010 | 04:08 AM
Z1 Performance
Former Sponsor
The diameter of them does not allow those Swift springs to work without using the SPL midlink. Z rear springs are tapered, Swift race springs are constant diameter. That is why those are listed as 'coilover springs' because they are intended for use with coilover setups, where height is adjustable. They are not bolt in lowering springs ala Tein S Tech, Hotchkis, Tanabe GF210, etc etc. The SPL midlink out back satisfies that requirement, and would then require an appropriate shock to me mated to it. And no, they cannot be used up front either, unless again, it's on a coilover setup that uses those diameter/length springs
