08 Nismo w/TCS does it have YAW Rate??
Old Aug 9, 2010 | 02:52 PM
190hpkilla's Avatar
190hpkilla
Default 08 Nismo w/TCS does it have YAW Rate??
Ok Short story Long LOL
08 Nismo w/TCS
Cant do nothing aggressive like sliding though corners, drifting, 180s,360s. Seems like ECM cuts the power.
My research led to me that ABS and Trac are 2 systems. Since I dont have VDC I cant pull any fuses.
However I found out that YAW rate sensor under the center console if un plugged will allow me to do whatever I want.
The delema is this....I know for sure Z with VDC has Yaw rate. Does my Z without VDC also have it?
I need for sure answer from someone with repair manual or EDM
I dont want to spend 600 on blackbox for few fun days out of the year.
Thank you
Old Aug 9, 2010 | 02:58 PM
NISMO_558's Avatar
NISMO_558
Just turn the TCS off
Old Aug 9, 2010 | 03:11 PM
DavesZ#3's Avatar
DavesZ#3
The Yaw/G sensor is only on the VDC equipped cars. TCS can be turned off by pressing the button.
The fuse that gets pulled is the brake fuse, it disables everything electronic associated with the brakes.
Old Aug 9, 2010 | 04:05 PM
190hpkilla's Avatar
190hpkilla
Ever Driven an 08? Nismo? And I mean Driven it HARD!
If pressing the button was that easy I wouldn't be here. LOL
Yes I know about the brake fuse for stand still burnouts.
Even with trac off the car is holding back and can barely make burning u turns or even hard turns. Dont get me wrong it moves but holding back.
My previous Z 2004 never had trac issues like this. The newer they get the more complicated.
Old Aug 9, 2010 | 04:41 PM
Nismo#1554's Avatar
Nismo#1554
Something must be wrong with my VDC because when I turn it off my traction control is off.
Old Aug 9, 2010 | 04:46 PM
You are my idol.
Old Aug 9, 2010 | 04:59 PM
350z 6spd's Avatar
350z 6spd
The TCS is completely turned off when you push the button...
NISMO_558's Avatar
NISMO_558
Why yes I have, what's your point?
Old Aug 9, 2010 | 05:24 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there no yaw in early non vdc z's no idea on a nismo but I suspect no
And now you know one of the many reasons a stock vlsd is a paperweight and nothing more
Old Aug 10, 2010 | 02:16 AM
SamSpicer's Avatar
SamSpicer
Im pretty sure my nismo can do whatever (drifting, etc.) i want it to do just by turning off the TCS button..
Old Aug 10, 2010 | 03:51 AM
Ataru074's Avatar
Ataru074
I have an '08 nismo... if pushing the TCS button doesn't allow you to do aggressive driving, 180s and 360s.. more likely there is a big issue in the hardware and software between the seat and the steering wheel... I'd try to fix that first.
Old Aug 10, 2010 | 01:54 PM
NISMO_558's Avatar
NISMO_558
Old Aug 10, 2010 | 01:56 PM
KingBaby's Avatar
KingBaby
Hardest Setting
I have an '08 nismo... if pushing the TCS button doesn't allow you to do aggressive driving, 180s and 360s.. more likely there is a big issue in the hardware and software between who sits in the seat and the steering wheel... I'd try to fix that first.
fixed
I found it very funny...
OP doesn't know what he's talking about...
Old Aug 12, 2010 | 03:19 PM
NightRider88's Avatar
NightRider88
Mine Gets Sideways Just Fine....
Old Aug 12, 2010 | 03:52 PM
Lakeside's Avatar
Lakeside
Just Mod the F' out of it till it does!
I am not even boosted and with my current Mods I can throw my car every which way! Not that I do.... But I do enjoy drifting on and off ramps sometimes.
Zim
nanotech
Oct 2, 2015 05:02 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
