Installed LED Daytime Running lights
Old Sep 4, 2010 | 11:10 PM
deezz's Avatar
deezz
It has to do with spacing also. The LED's in the bumper reflector are at the edges of the car. The placement of the LED's in that location keeps with the wide stance of the Z.
When you put lights towards the center, it "narrows" the stance of the Z and just looks "aftermarket" and amatuerish.
Not hatin' ....just sayin'.....
Old Sep 5, 2010 | 04:32 PM
hellsy's Avatar
hellsy
Originally Posted by dcains
here's what I did on my '08 (21 LED's in each corner):
May i ask which LED's you used? I was just getting ready to perform similar with 10 LED's, but this is just marvelous...
Old Sep 5, 2010 | 10:01 PM
dcains's Avatar
dcains
Here you go:
http://www.oznium.com/led-flex-strips
I bought the 9.5", which has 24 LED's, and 3 were cut off so the strip fits the reflector housing perfectly.
Old Sep 16, 2010 | 09:26 AM
Blood Stone's Avatar
Blood Stone
Hi,
Sorry, this may be a noob question, but what wire do you tap into if you want to have them as DRL? I know it's the ignition wire, but are you running the wire all the way inside the cabin? I'm debating whether or not it's worth it to do this mod. Thanks!
Old Sep 16, 2010 | 12:26 PM
dcains's Avatar
dcains
Mine are just wired with the oem parking lights. The wires are easy to see/access as you're installing the reflectors. IIRC, the ground is black, the 12V+ is green, but if that's not right, just follow the wires to the parking light socket.
Old Sep 16, 2010 | 12:37 PM
Al Kapwned's Avatar
Al Kapwned
Looks like rice.
Old Sep 16, 2010 | 12:41 PM
Erik@R/Ttuning's Avatar
Erik@R/Ttuning
I agree and I think that is what makes one look so integrated and one look so much like an after thought.
Old Sep 16, 2010 | 02:32 PM
Blood Stone
Thanks for the info. but that's not exactly what I meant. I want to have the LED in the reflector to be on when the car is on - to use them as daytime running lights (DRL) - so I wanted to know what wire I can tap into for that. If I tap into the parking lights then the LED will only turn on when the parking lights are on. If you know what wire I can tap into, that be great. Thanks!
Old Sep 16, 2010 | 03:31 PM
dcains's Avatar
dcains
I understand, but I don't know off the top of my head what circuits you might be able to tap into under the hood. If someone else doesn't chime in, grab a voltmeter and see what you can find in the fusebox near the battery. The fuse for the radiator fans is probably switched with the ignition, as I've never heard the fans running after the engine is off, and there may be others.
Old Sep 18, 2010 | 02:27 PM
srsairbags's Avatar
srsairbags
Question
Originally Posted by Arnold K.
if I had the skills to do it...I'm sure you do too.
And before anyone asks, those aren't LEDs. They're CCFLs.
holy crap . . that looks awesum . . .where can i get sum ?
Old Sep 20, 2010 | 03:29 PM
vrbigdish's Avatar
vrbigdish
Heres the ones i made with amber leds from whelen(20 leds in each)-->
Old Sep 20, 2010 | 05:28 PM
KingBaby's Avatar
KingBaby
Hardest Setting
nice nice man
Old Sep 20, 2010 | 06:57 PM
srsairbags's Avatar
srsairbags
Wink
ok that was stupid . . where do i get the inverter and ccfls ?
Old Sep 20, 2010 | 07:47 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
It looks like a hot girl with bucked teeth IMO..
Old Sep 29, 2010 | 02:37 PM
Facilitator's Avatar
Facilitator
In the middle of blacking out/installing LED's in my clear reflectors
Ill post pics afterwards...
Old Oct 1, 2010 | 12:38 AM
08NismoZ's Avatar
08NismoZ
Originally Posted by KingBaby
take your time man...
remember what happen to the last boosted 'RED' nismo....
can't wait to see what you got in store!
What did happen to that Red Nismo? I've been looking around trying to see how many Nismo's have gone FI, but I only know of that red one, mine, and the 370Z Nismo that I think GTM did.
edit: Oh yeah and that sponsored one that doesn't really look like a Nismo anymore
Old Oct 1, 2010 | 12:50 AM
KingBaby's Avatar
KingBaby
Hardest Setting
last red one hmmmm
correct me if I'm wrong anyone
didn't it have one of the first turbo kits out for an HR then, the owner lost it on an on-ramp...
blamed it on the weather
Old Oct 1, 2010 | 12:57 AM
  #38
08NismoZ's Avatar
08NismoZ
Yeah i'm pretty sure it was the first one, that sucks he wrecked it.
Old Oct 4, 2010 | 10:41 AM
  #39
tribal_visionz's Avatar
tribal_visionz
Vrbigdish's setup IMO looks the cleanest, maybe because it looks like it could be stock.
The others, look like out of place fog lights.
Old Oct 4, 2010 | 11:25 AM
  #40
srsairbags's Avatar
srsairbags
does it make any sense to have an amber drl ? the reason im asking is that . .my white drls failed . . soo streetglow sent me amber ones saying that the white ones are out of production . . any opinions ?
http://www.streetglow.com/SGLFLAM?sc=2&category=5449
