Brandon3434's 350z Nismo #0277
Old Feb 28, 2012 | 05:51 AM
  #401
brandon3434's Avatar
brandon3434
Got the new bumper this past weekend. Once tax money gets here, I'll get it painted.
Old Feb 28, 2012 | 06:17 AM
  #402
BoomerZ33's Avatar
BoomerZ33
slap those canards on bro!
Old Feb 28, 2012 | 06:44 AM
  #403
brandon3434
Old Feb 28, 2012 | 06:48 AM
  #404
jerseystyle's Avatar
jerseystyle
Canards
Old Feb 28, 2012 | 07:09 AM
  #405
KingBaby's Avatar
KingBaby
Hardest Setting
he's having some made!
Old Feb 28, 2012 | 08:59 AM
  #406
jerseystyle
I did not know that
Old Feb 28, 2012 | 09:02 AM
  #407
musubi's Avatar
musubi
say wuuut
Post pics when you get em!
Old Feb 28, 2012 | 09:27 AM
  #408
BoomerZ33's Avatar
BoomerZ33
Originally Posted by jerseystyle
I did not know that
he posted it on facebook. someone in his area makes MCR replicas or something
Old Feb 28, 2012 | 11:41 AM
  #409
brandon3434
I am meeting up with the guy making the canards next week. Hopefully Paul (the dude with the silver nismo w/ graphics on the side) will get me some good pics then I will forward them to the guy making the canards.
Old Feb 28, 2012 | 12:17 PM
  #410
Lakeside's Avatar
Lakeside
The trick is matching the contour/curvature of the V3 bumper! I took some detailed pics. What your looking for is pics with measurements.
https://my350z.com/forum/nismo-350z/...ds-are-in.html
Old Feb 28, 2012 | 03:00 PM
  #411
KingBaby's Avatar
KingBaby
Hardest Setting
The two of them together is too much for me looks wise...
I like just the lower one.
In for results
Old Mar 9, 2012 | 05:49 AM
  #412
jerseystyle
Originally Posted by brandon3434
Also, something else Joe @ Z Speed Performance had for my z, was a Wilwood Master Cylinder. Here's why this is nice:
If you have an HR, and you want an aftermarket clutch, then its added pressure will cause your slave cylinder to go out very quick, which will cause you to need a heavy duty slave cylinder to handle the pressure. With the new slave cylinder, the stock master cylinder will not be able to force enough hydraulic fluid to the slave cylinder, which will result in the clutch pedal dropping to the floor or not being able to engage into gear correctly. I was experiencing all of these problems, in this order, so now with the heavy duty master cylinder, it effectively forcees enough fluid to my slave cylinder, which results in a perfectly operational clutch pedal.
What a mouth full! (Thats what she said.)
Anyways, also heres a pic:
*EDIT* After owning this for a few months, the z drives perfect. No more of the clutch pedal dropping. It basically feels stock, but its working perfect. My/Joe@ZSpeed's goal was to have a perfectly operational clutch pedal to go along with a heavy duty slave cylinder, that is needed to help compliment an aftermarket flywheel/clutch. If you have issues with your clutch pedal after an aftermarket flywheel/clutch/slave cylinder install, this is the fix!
Awesome! My parts list for when I replace my clutch keeps growing and growing
Old Mar 9, 2012 | 05:54 AM
  #413
brandon3434
^YES, what clutch/flywheel did you decide on?
Old Mar 9, 2012 | 06:12 AM
  #414
jerseystyle
No decision yet. Recommendations?
Old Mar 9, 2012 | 06:37 AM
  #415
brandon3434
Well if I could do it all over again, I would get a Stage 3 Southbend clutch and a Southbend DXD 1 piece flywheel.
Old Mar 9, 2012 | 07:09 AM
  #416
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
I would do the Stage 2 TZR unless you're FI or want a heavier pedal feel.
I put this in the my 370Z with the DXD flywheel and it pretty much rocks, Much better than stock, Smooth from a stop and shifts soo fast, it just falls into gear with the lighter disk weight even at redline.
Brandon, you need to drive this
Nismo Diffuser is here waiting on your car also
Old Mar 9, 2012 | 06:14 PM
  #417
jerseystyle
I was thinking Stage 2 as well. Stage 3 seems like overkill for a NA car with minimal bolt-ons.
Old Mar 9, 2012 | 08:27 PM
  #418
brandon3434
^True, stage 2 is probably best for daily driving. And I know Joe!!!!! I can't wait, I just gotta fix my bumper...
And idk if I want to drive your 370z, will only make me want one lol...jk I'LL DRIVE IT, THANKS.
Old Mar 11, 2012 | 03:17 PM
  #419
KingBaby's Avatar
KingBaby
Hardest Setting
any update on the bumper/carnards/mystery diffuser?
Old Mar 12, 2012 | 07:36 PM
  #420
brandon3434
The canard guy isn't answering my calls/txts, so I'm not sure on that one. I should be dropping my bumper off this week. I drove my z for the first time in over 3.5 months yesterday when I took the bumper off...MY GAWD I MISS THIS THING!
