View Full Version : Engine
Pages :
16]
17
- [FS]: Rev Up Oil Pump
- [FS]: APS Oil pan w/ Fumuto Drain Valve
- [FS]: Pathfinder Rear Coolant Mod / Modified Coolant Pipe
- [FS]: ARP L19 Headstuds
- [FS]: Cosworth Headgasets, Solid motor mounds, grounding kit
- [FS]: VQ35DE Engine Parts
- [FS]: UR Polished Alt. & Idler Pullies, OEM VTC Sprockets
- [FS]: Hks fcon vpro
- [FS]: HKS FCon VPro Key
- [FS]: Turbo XS UTEC with MAP sensor for 350Z
- [FS]: Fuel pressure
- [FS]: Engine bay wiring harness
- [FS]: Daytona Blue Timing Chain Covers
- [FS]: Ruby Red Cam & Timing Chain Access Covers
- [FS]: Powdercoated Timing Covers
- [FS]: Haltech Platinum Pro
- [FS]: Gates Underdriven Belts
- [FS]: Built vq35de long block for sale
- [FS]: Haltech EMS, Polished Cosworth Plenum, 1200cc Injectors
- [FS/FT]: 03-06 Exoticspeed Racing Pulley Kit
- [FS]: Rare JDM Engine Harness Cover Matte Black
- [FS]: SFR 3 in 1 Catch Can, PS, and Coolant Reservoir
- [FS]: 1 coil pack and MAF sensor
- [FS]: zeetoyz 3 pc fluid cap set RED
- [FS]: Complete 370z engine part out VQ37 st louis, mo
- OEM [FS]: OEM Fan Shroud / Injen Short Ram Intake
- [FS]: UR Stock Size Lightweight Pulley 07-08
- [FS/FT]: CF engine cover & CF battery/brake fluid covers
- [FS]: Manley Turbo Tuff I Beam Con Rods! VQ35 NEW!
- [FS]: EAGLE RODS (brand new) for VQ35DE
- OEM [FS]: Alt, PS pump, rack, starter, mounts, and more...
- [FS]: Crank Pulley, Passenger Coolant Pipe
- [FS]: 220AMP OEM Style Alternator NEW!!!!! Plug n play!
- [FS]: ARP Head stud kit for vq35de, BNIB 150$ shipped
- [FS]: ARP Main stud kit 202-5801 vq35de. BNIB 125$ shipped
- [FS]: AMS Black lightweight crank pulley, BNIB 100$ shipped
- [FS]: HR Stillen Underdrive Pulley+ Belt
- [FS]: 07-08 Cobb Accessport
- [FS]: Square Greddy Catch Can
- [FS]: Cosworth Intake Manifold
- [FS]: Haltech full setup! Dual WB02, Boost Control, etc
- [FS]: ARC Oil and Rad Cap
- [FS]: VQ35HR from 2008 NISMO 350Z +/- 32k Miles
- [FS]: Stainless Solid Motor Mounts!!!
- [FS]: Eagle Rods
- OEM [FS]: Front timing cover cam covers
- OEM [FS/FT]: Crank Pulley
- [FS]: Cosworth Plenum Polished $800 shipped
- [FS]: BC 264 Cams
- [FS]: Front and Rear Polished Timing Covers
- [FS]: NEW 07-08 vq35hr OEM NISSAN OIL PUMP
- [FS]: Mishimoto Racing Thermostat
- [FS]: Ferrea dual valve springs
- [FS]: Pauter Rods and CP Pistons
- [FS]: Nismo R-tune cam (non rev up)
- [FS]: Altered Atmosphere Fuel Pressure Adapter (southern VA)
- [FS]: OEM fuel pump
- [FS]: JWT oil pan spacer
- OEM [FS]: OEM injectors
- [FS]: Motordyne Engineering Coolant Control Valve (CCV)
- [FS]: Valve Covers - Ruby Red
- [FS]: AAM oil pan spacer brand new condition
- OEM [FS]: Ignition Coils, 6 Total
- [FS]: PTE 1200cc Injectors
- [FS]: Ruby Red Intake - Kinetix Owners Come In
- [FS]: Deatschwerks 800cc Injectors
- [FS]: Coil Packs - Sold Individually
- [FS]: Deatschwerks 1000cc Top Feed Injectors New in Box
- [FS]: CJM Fuel Rails
- [FS]: NGK Iridium LFR5AIX-11 QTY = 2 $10 for both
- [FS]: NGK AFX Wideband o2 Monitor
- [FS]: Remote Oil Filter Adapter
- [FS]: TurboXS catback
- [FS]: 5/16 plenum spacer
- OEM [FS]: 2009 GTR 550cc Injectors
- [FS]: Cosworth High Pressure Oil Pump
- [FS]: Used ARC Radiator cap...!! LOOK..!!
- OEM [FS]: VQ37VHR - 14K Miles - $2500
- [FS]: TurboXS Tuner wide band AFR
- [FS]: NGK IX Iridium Spark plugs __________[$40]____________
- [FS]: OEM Injectors - 06 G35 Rev-Up (24k)
- [FS]: Full Haltech Package!! EMS, WB,BCS, 3bar MAP, gauge
- [FS]: RareJDM Polished Wiring Harness Cover
- [FS]: Utec with Map sensor W/600cc base map
- [FS]: vq35de complete non rev
- [FS]: Built VQ part out, some OEM
- [FS]: Turbo xz utec
- [FS]: UR underdrive crank pulley. $150
- [FS]: FS: AAM Spec AAM Fuel Pressure Gauge Adapter for OEM Fu
- [FS]: JDM G37 VQ37HR engine
- OEM [FS]: parts
- [FS]: Baller Bolts Burnt Ti Bolts
- [FS]: 440cc Injectors/ OEM Fuel Pump/ OEM Injectors
- OEM [FT]: Need non revup vqde wire harness
- [FS]: front timing cover, polished plenum, oem fans
- [FS]: MD Basic 5/16" plenum spacer
- OEM [FS]: OEM Radiator and Oil Caps
- [FS]: Brian Crower Valve Springs and Retainers
- [FS]: (6) Greddy 720cc Top Feed Injectors
