Purge show off, AWSOME!!!
Shortly after I spent all day doing the install.
Anyone know where to tap off the fuel line?
Thats all I have left to do and I'll be good th spray.
It seems alot of people are having problems installing these
kits as far as tapping the fuel and wiring to the TPS,
personally I only found the pedal position sensor to have
the right voltage for this kit. If anyone else has hooked
this thing up to the TPS, let me know how it performs.
Detailed pictures of the fuel line would be a plus.
HAPPY TRAILZ.
HAPPY TRAILZ.
Originally posted by dreamy-z
Let me know what you think. I think It looks great.
I didn't think it would shoot that far. I'm impressed my self.
Anyways, here is pics of my install.
https://my350z.com/forum/showthread....threadid=98865
Originally posted by Rickdogg
Wow. What did you use for the purge line?
Great pics by the way, only question is, where is it you tapped
into the fuel line. Is that T'd on the passenger side of the Z.
Which wire is the TPS wire?
Also if you're using a window switch (i hope you are) which wire did you splice into for the tach sensor?
PS that's quite a big purge shot, you'll run out of nitrous pretty fast that way and I can imagine the guys at the track not being too happy being sprayed on by n2o I'd suggest a bit smaller purge line....just my 0.02 cents
3/16 Brake line with the proper compression fitting.
Is that right before the first EVAC port that reads 1 PSI.
I also went as far as to going to my local nissan dealer and purchased a set of fuel dampner O-rings. This is a must for those of you out there experiencing trouble with your adapter leaking.
Fueldampnerorings Part#16618-10V10
Tochigi_236
Sep 27, 2015 03:40 PM
