Nitrous Oxide Too soon, jr.
What is a safe but powerful shot to run on stock engine
Old Dec 31, 2004 | 06:04 PM
mjedens's Avatar
mjedens
Default TheBigShow
Sounds good !!
Old Dec 31, 2004 | 07:02 PM
mrtomcat's Avatar
mrtomcat
Originally posted by jake-trackpack
75 shot is fun but i need bigger. I think i'm going to go at least 125, what is this eManage?
eManage is a piggyback ECU from Greddy
http://www.greddy.com/prod_e_manage.htm
Old Dec 31, 2004 | 07:25 PM
nastyZ's Avatar
nastyZ
I've been running a 125shot for the past 34k miles, without the use of a piggyback. My car has a bit over 41k miles and still runs strongs.
As long as your nitrous is installed by a professional, you really don't need to worry about anything. There's been cases of people installing a 50 shot and damaging their engine
My set only used a step cooler plugs and 100+ octane. I've even ran it a few times with 91+ octane without any problems...
Old Dec 31, 2004 | 09:01 PM
Street Visionz, Inc.'s Avatar
What type of piggyback do you use?
Old Jan 1, 2005 | 01:27 PM
jake-trackpack's Avatar
jake-trackpack
What size jets are those you use with the 125 shot? Also which system are you using? NX?
Old Jan 17, 2005 | 04:43 PM
Speedracer's Avatar
Speedracer
A "professional" is not a guarantee of a good installation. I have found that although it may take me more time, nobody will take as much care and attention as I will doing an install myself.
Also, can you give us some specifics on people blowing ther engine on a 50 shot? What happened? Thanks.
Old Jan 17, 2005 | 05:34 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
what's the recommended nitrous kit? I want to use a kit with simple installaion (self install), and also has everything I need... Can I get a 75shot kit for around $500?
Old Jan 17, 2005 | 08:01 PM
mrtomcat's Avatar
mrtomcat
I'd recommend investing in a full kit like the NX EFI + Genx II upgrade you can get that for around $800 I believe.
If you want to go low budget NX now has a entry level kit that should fit your budget called Main Line, here's a link:
http://www.nitrousexpress.com/mainli...stomer.psd.pdf
Old Jan 18, 2005 | 07:52 PM
nitrous350's Avatar
nitrous350
Befor I'm Install APS TT KIT on my VQ35
I used Nitrous 64(nitrous)28(Fuel) Jet on 91 Octane Pump Gas
Then when I Overhauling for Forged Internal My Piston and Cylinder , Valve are Very nice look........NO PROBLEM !!!
If 64/28 (A/F Ratio = 11.5:1) Jet What is the shoting H/P?????
Now I had a APS TT kit (11 PSI Boost) , I try to shot some Nitrous Top of my Boost
What is Jet Size 50 and 75 HP shot (Fuel Pressure @ about 68PIS)
Old Jan 19, 2005 | 02:56 PM
jake-trackpack
thanks, Does it matter what kit you use? All jet sizes should be the same right regardless the kit right?
Old Jan 19, 2005 | 06:30 PM
mrtomcat's Avatar
mrtomcat
no every kit is different
Old Jan 19, 2005 | 11:10 PM
jake-trackpack
How is that possible, because nitrous is the same no matter what kit you have so the jet size should be too right?
Old Jan 19, 2005 | 11:12 PM
mrtomcat's Avatar
mrtomcat
it's also different on some car applications.
I believe is has to do with the solenoid size (guessing here)
Old Jan 21, 2005 | 02:11 AM
jake-trackpack
I guess that would probably explain it. I can't think of anything else.
3vilbunny
Sep 13, 2015 12:31 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
