Nitrous Oxide Too soon, jr.
Weak nitrous shot?
Old Oct 4, 2005 | 10:24 AM
mrtomcat's Avatar
mrtomcat
that's very odd, the window switch does nothing else but open a circuit and close a cicuit on a specified range on the nitrous circuits, does not do anything on the car.
You should investiage that some more. I believe people using the MSD had to do some form of modification.
Old Oct 4, 2005 | 03:18 PM
JRaptor2000's Avatar
JRaptor2000
shouldn't the window switch just cut the power from the arming switch when it's not in the window?
Old Oct 4, 2005 | 03:26 PM
mrtomcat's Avatar
mrtomcat
exactly, that's why it makes no sense that the switch could push the car into limp mode
Old Oct 5, 2005 | 05:16 PM
JRaptor2000
thats what i thought. i guess i'll be wiring that up for him...
zex told him that if the nitrous pressure in the line was too high the solenoid wouldn't open as a safety precaution. why would the pressure be too high if this was the case?
Old Oct 5, 2005 | 09:14 PM
mrtomcat's Avatar
mrtomcat
if the bottle is subjected to sunlight, lots of heat you can fairly easily go above 1050 psi, that's why you need a pressure gauge to check.
If you're in an extra hot area I'd recommend to invest in a "fire and ice" device by NX.
It functions as a bottle heater to get pressure up and as a cooler to get pressure down if too high.
Old Oct 7, 2005 | 02:24 PM
JRaptor2000
anyone have directions for wiring up the window switch? just to make my life a bit easier.
Old Oct 8, 2005 | 07:34 AM
done12many2's Avatar
done12many2
Originally Posted by BoOsTedz33TT
even with a 125 shot, i dont think you got 375,i bet 295-305rwhp
I put down 337 hp and 387 tq with a 75 shot. Prior to the nitrous I was @ just over 260 on the motor alone.
sales@czp
Sep 23, 2019 03:30 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
ddegrande21
Sep 6, 2015 11:15 AM
