Nitrous Oxide Too soon, jr.
what are you using to tap the fuel
Old Oct 2, 2005 | 06:18 PM
faster than u's Avatar
faster than u
Default what are you using to tap the fuel
well are fuel line sucks , its a hard plastic which is making everything difficult. can you guys tell me what you are using to tap the fuel line. hurry i dont have a car to drive
Old Oct 2, 2005 | 06:36 PM
QuadCam's Avatar
QuadCam
www.ptpmotorsports.com
http://www.ptpmotorsports.com/fuliad.html
Old Oct 2, 2005 | 06:57 PM
faster than u
does it work well , did you have to modify it or anything, do you have to cut the fuel line
Old Oct 2, 2005 | 07:04 PM
QuadCam's Avatar
QuadCam
nope. it is beautiful. no cutting or butchering of anything.
It fits in between 2 items. I don't know exactly what they are called. Sorry.
anyway, you remove the 2 factory bolts. Pull the fitting off of the housing. Then, put the adapter onto the housing. Place the fitting onto the top of the adapter. Install and tighten 2 new, longer bolts. That's it.
It comes with the adapter, 1/8" to -4 fitting, o-ring, and longer bolts. You need to use thread sealer on "1/8" to 04" fitting.
I have had no leaks at all with it!!! I Highly recommend it
Old Oct 2, 2005 | 07:06 PM
faster than u
thanks bro
Old Oct 2, 2005 | 07:11 PM
QuadCam's Avatar
QuadCam
If you call them, speak with Jon.
Old Oct 3, 2005 | 11:12 AM
Gators2001's Avatar
Gators2001
Old Oct 4, 2005 | 03:19 PM
JRaptor2000's Avatar
JRaptor2000
it fits between the fuel pressure regulator or filter and metal fuel line/fuel rail. didn't look at my buddies Z close enough to see exactly what they are. its on the left hand side of the engine bay right next to the plenum.
Old Oct 12, 2005 | 02:38 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
we have a fuel T that is similar to what Stillen uses in their supercharger kits:
http://performancenissanparts.com/ca...oducts_id=2799
It fits in between the fuel rail and the fuel line, and allows you to use a 4AN fitting to tap into the fuel system for whatever purpose, weather it be an extra injector, nitrous fuel line, or fuel gauge... We also have the 4AN fitting:
http://performancenissanparts.com/ca...oducts_id=2997
Old Apr 19, 2006 | 06:41 PM
sflg35's Avatar
sflg35
KP Technologies
sorry to bring this from the dead but this is the one you guys are talkin about right??
http://ptp.tuningmotorsports.com/pro...cat=420&page=1
gettin ready to order mine tonight
