Nitrous Oxide Too soon, jr.
Edelbrock kit results!!
Old Feb 26, 2006 | 02:37 PM
virgilio7's Avatar
virgilio7
that is why each kit has it's own jets.
Old Feb 26, 2006 | 03:14 PM
bacalhau16's Avatar
bacalhau16
the nx jets, flow more nitrous, but i dont think its just the jets, i thought it was the actual calculation that nx uses vs. the calculations that nos uses!
Old Feb 26, 2006 | 05:13 PM
1bad350z's Avatar
1bad350z
i posted earlier in this topic about putting the 68/35 jets in and somebody said that was way to big of a shot??
i just found this site and its the same jetting i was gonna use!
http://home.ican.net/~jsetter/nitrous.html#jet
i made 231whp & 234trq on just motor, then used the jets sizes that a couple guys said were 150shot ( i got a 55N/30F) and made 302whp 356trq (a/f was really really rich low 10's) so we took the 30 out and installed a 26 and made 312whp and 360trq (a/f was 11-1), so thats only 81whp and 126ft lbs?? bottle pressure was 950psi
what do you think i should do, up the nitrous and try that, or change to a shark nozzle and use the nx jets???
Old Feb 27, 2006 | 03:46 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
my car is sick man, with the 53 and 28 perfect 12.3s A/F try some bigger jets if you want and let me know how that works out, then i will change mine out, hehehe maybe i will go dyno my car today if possible...
Old Feb 28, 2006 | 08:53 AM
Old School's Avatar
Old School
Shift_Boost
Originally Posted by virgilio7
u have awesome times but what did u use to retard timing? cause 125 shot is big and you need to retard at least like 6 degrees
That's overkill bro. If you retard timing at all, 2 degrees is all it would take for 100-125 shot. I think the stock ecu will pull timing if the motor knocks anyway.
Old Feb 28, 2006 | 09:09 AM
virgilio7's Avatar
virgilio7
it's not how you see it. its 2 degrees on a 75 shot. and every 25 another 2 degrees.
knock sensor detects detonation and pulls timing. but is completely different when you knock on a 125 shot than regular gas. if the timing is not retarded then the fuel is going to detonate early, before the cylinder comes up. is like hitting the cylinder with a hammer when is coming up.
really bad for your engine.
Old Feb 28, 2006 | 09:20 AM
Old School's Avatar
Old School
Shift_Boost
2 degrees for a 75 shot is the rule of thumb, yes - not disagreeing there. But that is not the rule of thumb with nitrous express. That is one of their better qualities. Check on there site and ask a few guys around here what they do. Pulling 6 degrees of timing is just too much for an NX kit on the Z. Performance would suffer noticably. Now if we're talkin NOS, ZEX, VENOM, etc....then yes, I could see where you are coming from. I'm not calling you out or anything, just clarifying. All this stuff is straight from the horses mouth. John Stewart - former employee/designer of NX products who lived here in Houston until he died a few years ago. Nice guy, loves to shoot the ****. If he is wrong, I don't know who is right! lol.
Old Feb 28, 2006 | 09:25 AM
virgilio7's Avatar
virgilio7
125 shot is too high to run on stock timing. sooner or later something its going to break. either today or a couple of years later.
Old Feb 28, 2006 | 09:35 AM
virgilio7's Avatar
virgilio7
but then again. i don't know why the don't require a timing retard.
Old Mar 3, 2006 | 09:21 AM
Old School's Avatar
Old School
Shift_Boost
I'd retard timing 2 degrees on 125 shot. but 75 or 100....I'd leave it alone.
Old Mar 17, 2006 | 01:32 PM
QuadCam's Avatar
QuadCam
I'm running a 53/31 NX setup with no electronic timing controls etc. I did go w/ 1 step colder NGK iridiums at the stock gap.
My best time has been a 13.02 @ 110.5 in a G35 Sedan.
Old Mar 17, 2006 | 01:45 PM
Audible Mayhem
My350z
wanna race there buddy?? hehehe just kidding yeah that sedan is fast, hopefully you can bring it to OSW next wednesday and race that black Z that will be running 11s....
Old Mar 17, 2006 | 05:08 PM
1bad350z's Avatar
1bad350z
WITH THAT TRAP YOU CAN RUN SOME LOW 12'S ON GOOD TIRES, WHAT DID YOU USE FOR THAT RUN???
Old Mar 17, 2006 | 07:28 PM
Audible Mayhem
My350z
he has a G35 sedan with the same nozzles i do, 52 N and right around 30 F jets. his car is very fast...
i believe he was on the stock potenzas for that run...
Old Mar 18, 2006 | 11:01 AM
bacalhau16's Avatar
bacalhau16
i agree with a 110mph trap speed, he should see easy 12's all day. none the less, a pretty quick g.
Quadcam, did u add anything else to the nx kit, like a msd rpm window switch or anything like that?
what are we saying a 53/31 shot equates to? around or just over a 100 shot?
Old Mar 18, 2006 | 03:30 PM
Audible Mayhem
My350z
andrew (quadcam) doesnt come on these boards too often, i know he has a WOT switch but i dont think he has any thing else on there. he has the pretty basic setup up like mine, NX kit, bottle warmer, etc
yes that equates to 80 hp to the wheels, roughly a 100 shot...
Old Mar 18, 2006 | 08:27 PM
bacalhau16's Avatar
bacalhau16
wow, thats really cool. i dont want to exceed spending over $1000 on a nitrous kit all together cause thats just too close to F/I!
Old Mar 19, 2006 | 05:28 PM
  #38
QuadCam's Avatar
QuadCam
hey guys.
I run a 52 N / 31 F NX jets.
Activation is on a WOT microswitch. I have the usuals......heater,purge, digital pressure gauge, and a remote opener.
My run was on stock sedan 18" goodyears. Unfortunately, that was my 1st nitrous run at the track. All other runs have resulted in big wheel hop followed by no clutch going into 2nd gear!!!
Old Mar 19, 2006 | 09:16 PM
  #39
bacalhau16's Avatar
bacalhau16
time for a new clutch and some tires! nice setup. not too much, just the essentials.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
