Nitrous Oxide Too soon, jr.
Nitrous kit soon...few questions
Old May 24, 2006 | 02:25 PM
rico3682's Avatar
rico3682
Default Nitrous kit soon...few questions
I just picked up a NOS wet kit from a friend of mine. The kit came with all the lines and solenoids, bottle, bracket and bottle heater as well as Autometer AF and Nitrous pressure gauges. After much searching, I have come to the conclusion that I need a few more parts: rpm window switch, full throttle switch, one step colder plugs and a fuel line adapter. Does anyone have any suggestions for parts? I was told to get the SPX fuel line adapter, but not sure where to get it. I found a window switch/ full throttle switch all in one unit on the dynotune website, any opinions? Also, what plugs do you all suggest? I just want to make sure I have everything I need. Thanks in advance for the help.
-Eric
Old May 25, 2006 | 03:11 AM
Nowell's Avatar
Nowell
National Z Club
NGK Iridium is what I use, one step colder. Dont have the part number but you can find em on places like Intense Power. I love Dynotune, have a few products from themand highly recommend them! As or the fule adapter, check out AAM they make one also that I use. Its not hard to put on, just make sure you put a bit of oil on the o-rings. Other than that, shounds like your all set to spray! Have fun!
Old May 25, 2006 | 04:02 AM
rico3682's Avatar
rico3682
Thanks for the reply. I am going to order the AAM fuel adapter and I just ordered the NGK plugs. I also picked up the Dynotune digital nitrous pressure gauge and the Dynotune swithc panel "gauge" (looks like the shape of a guage but has all the switches). So no the only thing left is a TPS switch or Window Switch. Dynotune has a couple, not sure which to get. They have one that is just a TPS and they have another that is a TPS and Window Switch all in one...any advice there?
Old May 25, 2006 | 04:03 AM
rico3682's Avatar
rico3682
oh, and how would you go about mounting two gauges in the Nav cubby?
Old May 25, 2006 | 05:27 AM
Nowell's Avatar
Nowell
National Z Club
I use the same Dynotune guages, and have them mounted on an A pillar guage pod. If you dont have a form of EMS (I use the UTEC to work as a window switch), then get the setup that has the TPS/window together. Its better to sped a little extra to be safe.
Old May 25, 2006 | 05:34 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
LFR6A11 is the part number on the plugs
good luck with the nitrous !!!
Old May 25, 2006 | 07:48 AM
rico3682's Avatar
rico3682
Thanks for the help guys. I think I will order all the DynoTune parts today. Just unsure of how to mount the gauges in the nav comparment, might just get two gauge cups and put them side by side. Also, has anyone mounted the bottle in the spare tire well, I want it somewhat hidden? Last question, the fuel line adapter. I was looking at the AAM, but it is pretty pricey. I wouldnt mind looking into the SPX unit. Does anyone know the part number I need and the price? are these the only two options? Thanks again guys.
-Eric
Old May 27, 2006 | 07:31 AM
rico3682's Avatar
rico3682
Ok, ordered the aam fuel adapter. and the dynotune gauge panel and digital nitrous pressure gauge. also ordered the colder ngk plugs. i also picked up a blown down tube. the kit came with a bottle heater, purge and everything else. So the only thing left is some sort of nitrous controller......window switch, tps....im unsure. Dynotune makes a two in one unit, anyone have any experience with it???
http://www.dynotunenitrous.com/store...?idproduct=194
Any help would be amazing...its the only thing I have left to get for the setup Thanks.
Old May 27, 2006 | 01:43 PM
Gators2001's Avatar
Gators2001
I love my Dynotune guages!
Old May 27, 2006 | 01:52 PM
jmcmorante's Avatar
jmcmorante
Post pics to see your set up after plz! Congrats!
Old May 27, 2006 | 02:11 PM
sein's Avatar
sein
I mounted mine in the spare tire well and when you put the carpet on top you can only see a little lump.
Old May 27, 2006 | 02:43 PM
rico3682's Avatar
rico3682
Thanks for the help everyone. I ordered the two in one TPS/Window switch. I am just waiting for all my parts to come in so I can have it all installed then dynoed. I will get pics put up when I am done. Has anyone mounted the solenoids in the Fuse comparment in the engine bay. Seems like there is enough room and things will be very hindden with the cover on.
Old Jun 4, 2006 | 08:23 PM
killerlexus's Avatar
killerlexus
Banned for Scamming
so you can use this to turn on and off at FULL THROTTLE or do you still need to mount a switch behind the gas pedal?
where would you tap in to for a signal? from CPU under passenger side or from the distributor? sorry dont want to noob it and be a statistic.
Old Jun 6, 2006 | 10:47 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Just wanted to add, I recently learned that Crawford Z Car (makers of the plenums) sell a 2 guage nav compartment guage holder, you may want to look into that if you dont want them on the A-pillar.
Old Jun 6, 2006 | 10:48 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Unfortunately for saying something so dumb your a newb Find the distributor on our Z's and take a pic then post it up
Old Jun 6, 2006 | 02:02 PM
Audible Mayhem
My350z
alberto, youre such a noob..... mine is right there!!!
Old Jun 7, 2006 | 09:34 AM
Alberto's Avatar
Alberto
Cranky FI Owner
LOL, yeah I see it now...its behind the hole in your bumper
Old Jun 7, 2006 | 09:45 AM
Audible Mayhem
My350z
why do you think its soo easy to advance my timing, i just turn it counter clockwise....
Old Jun 7, 2006 | 10:09 AM
Nowell's Avatar
Nowell
National Z Club
You guys are harsh, he really might not know, did you ever think of that?
Funny, but harsh =)
Old Jun 7, 2006 | 11:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Nowell you didnt know the fast Z's run 10mm Magnecore spark plug wires and MSD Ignitions/distributor caps? Damn man your really out of the loop...
