Nitrous Oxide Too soon, jr.
Nitrous Question
Old Sep 18, 2006 | 06:58 AM
BRAIN_Z33's Avatar
BRAIN_Z33
Default Nitrous Question
I Have An O6 Z Stock Only Exhaust.... And Was Wondering If It Can Handle A 75 Shot Of Nitrous? On Stock Engine, What Is The Best Way Without Sacraficing Dependancy, 50-75 Shot Whats Good?
Old Sep 18, 2006 | 08:33 AM
daz311x's Avatar
daz311x
go here...
https://my350z.com/forum/forumdisplay.php?f=181
Old Sep 18, 2006 | 09:34 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by daz311x
That was wrong...LMAO!!
Old Sep 18, 2006 | 01:37 PM
Old School's Avatar
Old School
Shift_Boost
75 shot is fine on stock block...do a search....you'll uncover alot of useful info.
Old Sep 30, 2006 | 06:49 AM
kostat26's Avatar
kostat26
i just bought a zex kit form another member. if i put in the 100 shot with one step colder plugs on my 06 with no timiming retard, would i be having any problems? (i did research too before anyone gets mad, but would rather have it 100% confirmed).
Old Sep 30, 2006 | 10:11 AM
Old School's Avatar
Old School
Shift_Boost
This has been covered in other posts, but I'll go over it again.
You can run up to 150 shot without management....would I do it? No. Have other done it successfully without blowing anything up? Yes. If you're running 100 shot, I'd invest in a reflash or a UTEC. That way, you can clean up the A/F ratio and retard timing when needed. Or you could play with the fuel jets to get the A/F ratio right when spraying which would only cost you dyno time. If you don't mind running rich on 100 shot, then go right ahead....otherwise, have it tuned (with management or just using the dyno). The 75 shot jets make a pretty good A/F ratio when spraying....Gives you about 100-125 lbs of torque too. A search on the nitrous forum will uncover plenty of ppl who have run 100 shot stock, without any problems...but like I said, use your own judgement.
Old Sep 30, 2006 | 10:50 AM
kostat26's Avatar
kostat26
i plan on getting a utec in the future but im goign to the track next week so wanted to know if i should push it to 100. so 100 with no tune or dyno time or any piggyback for 3 runs should be good with one step colder plugs. any suggesstions
Old Sep 30, 2006 | 02:31 PM
Gerxrow's Avatar
Gerxrow
There is no way to tell definitely. Yes, you should be fine, but what we are basically telling you with a big disclaimer is that the suggested jets from the manufacturers do not guarantee a perfect A/F ratio throughout the powerband.
I personally would not run 100 shot without some sort of engine management despite what others have done, and much less with no dyno time to atleast know where my A/F ratios are at.
Old Sep 30, 2006 | 06:08 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
you can safely run a hundred shot if you have some way of telling your AF ratios and adjusting the fuel jets accordingly...
Old Sep 30, 2006 | 08:48 PM
plumpzz's Avatar
plumpzz
silly question, but can someone find out you used nitrous prior to engine failure after uninstalling the nitrous..?
Old Oct 1, 2006 | 10:36 AM
ct350z's Avatar
ct350z
yes!!!
Old Oct 11, 2006 | 07:04 PM
nicholasm617's Avatar
nicholasm617
here u go.
http://www.dynotunenitrous.com/store...ousjetcalc.asp
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
