Nitrous Oxide Too soon, jr.
Nitrous Basics Thread, read here if you want nitrous for the first time....
Old Feb 16, 2014 | 05:08 AM
  #241
wls350's Avatar
wls350
I use a Nitrous express maximizer 4,
Nos is set to start at 3750 room and shut of at 6950 rpm,
Then I bring the Nos in with about 30% and ramp it up as it increases in rpm.
That way it's progressive, also set it to chase a specific wide band so set that to 11.5 and let it chase the afr.
Place emphasis on safety and enjoy it, personally bringing gas in so low is just adding so much strain on your motor.
You want the gas coming in closest to the torque peak as possible
Sent from my GT-I9300 using IB AutoGroup
Old Feb 27, 2014 | 03:07 PM
  #242
raybot's Avatar
raybot
Originally Posted by HieuVo350z
I have Zex full set in my car. The zex box is set up on on wot and the window switch is set in on your rpm. I have mine set on 4400-6700. The lower your rpm the higher the risk of something breaking. Nitrous creates a lot of tq.
ok so because I know that my kit have a WOT but is that also function as a window switch that only engage at 2500rpm and shut of before limiter?
or do I have to buy a window switch itself??
Old Feb 28, 2014 | 09:47 AM
  #243
wls350's Avatar
wls350
Buy a proper controller and stop messing around, 2500 rpm is literally looking for ****..
Old Mar 10, 2014 | 08:29 PM
  #244
IV_SD_350Z's Avatar
IV_SD_350Z
And bringing it back to life.....again..... anyone have anything to add?
Old Mar 11, 2014 | 06:13 AM
  #245
r3zon8's Avatar
r3zon8
there should be plenty of 350z specific kits available today. its a simple install, just make sure whatever kit you have comes with the fuel tap. AAM makes their own but im sure there are clones/alternatives by now.
Old Mar 11, 2014 | 06:14 AM
  #246
r3zon8's Avatar
r3zon8
Other upgrades for 'safe measure':
-Spark Plugs
Old Aug 24, 2014 | 09:24 PM
  #247
spooncer_DK's Avatar
spooncer_DK
Default Nitro 350z
So I want to know what nitrous kit i should get. I definitely want a wet system but which is best for the 350z? its a 2003 and im currently working on the engine. The max shot i"d use would be 200 (i'd probably just have a 100 in there most of the time), would getting better connecting rods be enough for the engine to keep it safe? any help would be great
Old Aug 25, 2014 | 06:08 PM
  #248
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Brands are mostly a matter of preference. Read through this thread if you haven't already.
Old Sep 26, 2014 | 03:28 PM
  #249
JustinZ33's Avatar
JustinZ33
Default Can someone please explain nitrous jetting for hr engine
I have a nitrous express kit and I have a 75 shot ( 41/22 ) in each intake but the installer said it still would only equal a 75 but now people are saying I have been running a 150 this whole time my car has been untuned on the 75 shot for about 2 or 3 months and I have went through at least 10 bottles so my question is have I been running a 150 shot untuned this whole time?
Old Sep 26, 2014 | 03:52 PM
  #250
1973camarolt's Avatar
1973camarolt
Contact NX themselves and ask, to be certain. You can measure the mass flow rate of nitrous and calculate the horsepower gains from there with your AFR and an assumed combustion efficiency. We do this with our race car:
https://www.flickr.com/photos/593as/...ream/lightbox/
Old Sep 26, 2014 | 04:54 PM
  #251
JustinZ33's Avatar
JustinZ33
I have getting so many different things even from NX I just want input from someone who has it so I can know for sure this is frustrating as hell
Old Sep 26, 2014 | 08:00 PM
  #252
3hree5ive0ero
Retired Admin
150 shot
Old Sep 29, 2014 | 11:36 AM
  #253
juicinjake's Avatar
juicinjake
yes... with that jetting you have been running around on 150hp shot untuned. that is correct. id pull your plugs and look for little speckles of aluminum embedded in the plug (caused by detonation).
Old Jan 1, 2016 | 08:15 PM
  #254
Yaaaayaaaay35's Avatar
Yaaaayaaaay35
Default Holley brand NOS system
I have a NOS kit from Holley for my car,
Called them and they said for a 100shot to run
Nitrous - 51, fuel - 34
And for 125 shot
Nitrous - 65, fuel - 38
Does this sound correct to anyone?
Just wanted some insight on this
Thanks
Old Jan 2, 2016 | 09:24 AM
  #255
3hree5ive0ero
Retired Admin
I strongly suggest that you start with the recommended size and monitor the AFR (via gauge or dyno) to fine tune it. Don't just put in the jets they tell you to without checking the AFR.
Old Jan 5, 2016 | 04:25 PM
  #256
Yaaaayaaaay35
So what would the recommended sizes be for a 100 shot? because those are the sizes Holley gave me.
Old Jan 6, 2016 | 01:53 PM
  #257
Conway_160's Avatar
Conway_160
He is saying run what holly says to run but ensure you use a afr guage to monitor it. All cars run diff so you may have to add or pull fuel.
Old Apr 2, 2016 | 08:41 PM
  #258
nismo_ninja's Avatar
nismo_ninja
Default Uprev?
For the op can the uprev do the same thing as the utec for nitrous tuning? Im very new to the idea of nos read the first post and scrolled through some but utec is discontinued and i have a uprev
Old Apr 5, 2016 | 04:18 PM
  #259
BakaN20's Avatar
BakaN20
Uprev can have multiple maps, one for your N/A tune, and another for your nitrous tune, where timing is not as aggressive.
Old Oct 10, 2016 | 02:13 PM
  #260
Z-olaf's Avatar
Z-olaf
So I'm looking at buying this
https://www.amazon.com/Nitrous-Expre...ds=nitrous+kit
And buying the obvious things like pressure gauge, etc.. Or
https://www.amazon.com/Nitrous-82220...0z+nitrous+kit
Which is made specifically for the 350z, but I'm not sure if it's worth the extra $200 for what it's offering. Any input into the two, and what more I'll need to buy with either recommended kit?
