Nitrous Oxide Too soon, jr.
Venom VCN-1000 in an 06 350Z
Old Dec 15, 2006 | 09:05 AM
97supratt's Avatar
97supratt
Actually, since you got it for free can you convert your dry kit to a wet kit? Some manufacturers have kits to convert, not sure if venom has it.
Old Dec 15, 2006 | 11:44 AM
MasterNele03's Avatar
MasterNele03
no they don't thats y I asked b/c i got it free I wanted to see if I could use it but it's apparent that it won't so I guess I'll just get rid of it.
Old Dec 17, 2006 | 06:51 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
thanks guys!!! i get soooo busy now a days, i miss these threads
one thing i have learned over the years, when it comes to something that can TOTALLY destroy your car and engine, dont skip steps and try to cut corners. nitrous is a serious thing, installed incorrectly it could blow your intake manifold right through your hood...
do it right, it doesnt cost that much, a nitrous kit with ALL the options is right over a grand brand new...
Old Dec 18, 2006 | 09:03 AM
RedondoG's Avatar
RedondoG
I started with a VEnom 1000 kit, and it was a disaster.
The electronics on one bank worked perfectly but the other bank never worked quite right. I took it back to Venom several times and they checked it out and said everything was OK, but it wasn't. I checked the unit out myself using a Cipher to verify how it was working.
The good news is that you only have to buy a fuel solenoid, nozzle, jets, WOT switch and window switch to complete the kit. Just throw away the electronics package and control switch.
Old Dec 18, 2006 | 09:07 AM
Old School's Avatar
Old School
Shift_Boost
Might be b/c the Z's electronics use low-voltage readings. Kinda like having to modify the MSD window switch. Regardless.....this is why everyone says NX/Zex....do it once, do it right.
Old Dec 18, 2006 | 11:34 AM
MasterNele03
what are the two banks that you are talking about all I have is 1 control module and what are the voltage readings b/c they said it can;t go over 5 volts or else you break stuff just like the zex and nx kit tell you but I;m not sure
Old Dec 18, 2006 | 05:53 PM
RedondoG's Avatar
RedondoG
this has nothing to do with voltage or signal waveform.
The venom has six orange wires that are meant to be tied into each of the injector wires. The injector signals are modified by the Venom electronics box. I was never able to figure out exactly how the electronics box works, but I do know that I only got increased injector pulsing to accomodate the nitrous injection on 3 cylinders (1 bank).
Old Dec 18, 2006 | 08:04 PM
MasterNele03
right exactly thats why I'm trying to figure out why 3 cylinders would be ok and not the other 3 and thats why I was considering using this kit even though it is a dry kit it's somewhat a mix of both b/c it does add more fuel, even if i do have to get a better fuel pump and a tune I mean I mine as well b/c in 6 mos. Im going to get a turbo kit either the greddy or STS if they don't take so long but for now I think the nitrous is sufficient.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
