Nitrous Oxide Too soon, jr.
Question on blow down tube
Old Dec 16, 2006 | 04:41 PM
eltness350's Avatar
eltness350
The Untouchable
Default Question on blow down tube
I'm putting a blow off cap and a blow down tube on and I was wondering how you guys routed it outside the car? I have a blow down tube but its only about 7" long. Thanks
Old Dec 17, 2006 | 07:12 AM
first350's Avatar
first350
where's your bottle located?
Old Dec 17, 2006 | 10:50 AM
eltness350's Avatar
eltness350
The Untouchable
the bottle is located in my trunk....just behind the passenger seat ... the reason i am asking is because last time i ran my car at the track they wouldnt let me run with the ic sprayer ...i had to take the bottle out of my car ....nhra rules state that it has to be routed outside of the car ....no one has had this problem??
Old Dec 17, 2006 | 07:01 PM
bacalhau16's Avatar
bacalhau16
That is a NHRA rule, and they wont let anyone at New England Dragway use nitrous without that either.
Im curious as to how people chose to route their blow down tubes also.
Old Dec 18, 2006 | 03:12 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
usually i would just drill a hole and aim it out on my cars,
i am sure that you could put a steel braded line that would slip over the blow down tube, i would guess like a -8 line maybe -6 and clamp it on and then run that out as well.
i would ask your tech at your local raceway if that would be sufficient..
Old Dec 18, 2006 | 06:54 AM
THE TECH's Avatar
THE TECH
You can always have a shop weld another piece of aluminum tubing to the one you have to make it longer.
Old Dec 18, 2006 | 08:06 AM
tenpenniesz's Avatar
tenpenniesz
I've added a steel braided line to the end of the tube. Tied it off and then used that to run outside the car. You should be okay with that as long as the line stays secured to the in the event the pressure seal breaks. To be safe check with the track tech for certain. The events that I have attended have been okay with the setup.
Old Dec 18, 2006 | 11:12 AM
eltness350's Avatar
eltness350
The Untouchable
thanks guys...really appreciate the info ..
Old Dec 20, 2006 | 03:47 PM
nosser's Avatar
nosser
in my old se-r i bought the right side tubing from home depot, and clamped it down to the blow down. then just route it out by the spare tire. there should be a hole there. The techs at my track were cool with it.
Old Dec 21, 2006 | 06:12 AM
Old School's Avatar
Old School
Shift_Boost
hide all your parts and the tech won't even know you're sprayin. lol
apex locator
Jul 23, 2021 02:27 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
