Nitrous Oxide Too soon, jr.
The big bad nitrous post
Old Jan 6, 2011 | 10:37 AM
  #281
Sparks03Max's Avatar
Sparks03Max
Originally Posted by Stock2Autocrozz
Confused over NA mods to bring starved front 2 cylinders AIRFLOW up a bit...anyone experience different results with stock vs Kinetix SSV or possibly thicker like APS for FLOW?
Mrev2 is what you want.
Old Jan 30, 2011 | 09:28 AM
  #282
John1006's Avatar
John1006
I have a few questions i hope you guys can answer. I've be reading so much lately on nitrous. I'm about to put a 75 shot on my 03 Z. I have the Zex box nitrous kit. I was wondering will the dynotune controller work with this? The controller that has a WOT switch, Window switch, and a gear lock out. Also one other thing, if i get test pipes, and i get the CEL, wouldn't the car think its running rich so it would lean out the a/f ratio, and be bad for nitrous. Thanks in advance for the help.
Edit: Well just stumbled upon the microedge. It has a lot of features. Would it play nicely with my Zex box?
Old Jan 30, 2011 | 03:22 PM
  #283
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
All electronics are interchangeable. After all, all they do is read voltages and activate solenoids (simplified).
With a 03 350Z, if you add non-foulers when installing test pipes, you shouldn't throw a code. Search the forum for more info.
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
Tochigi_236
Sep 27, 2015 03:40 PM
