My Nitrous Setup - 125 Shot - Pics
Originally Posted by jonb7007
I wonder what a 200 shot would do?
need some sort of Plenum like the kinetix to drive the n2o right in.
It would be fun to try though
Might even be easier on a 07 with the dual intake tubes though..
Originally Posted by skwid
I'd say you would want Direct Port for a 200 shot. The problem with just spraying in your intake tube with the stock plenum is that you probably get uneven distribution. Raising the pressure in 3 of the cylinders more than the others could be potentially hazardous to the Motor. If you went direct port then you would
Not true
Nice! Is this yours?
Click on his name to send him a PM.
Thanks! I know it's crazy. It actually barked the tires in 4th gear when it sprayed.
start saving for your build. took me 3 bottles to break a ring land and blow the tips clean off the spark plugs with 150 shot (366whp/438wtq). I had it tuned using the UTEC and had all the breather mods (i/e/h/spacer/test pipes/etc). Like someone mentioned earlier....125-150 shot doesnt get distributed well enough....direct port FTW!
I was wondering when you would chime in Old School.... I can't believe it broke it.
Oh well, I am going to make the trip to Forged Performance anyway and go Turbo. The Nitrous will be direct port afterwards.
Originally Posted by nicholasm617
god damn nice numbers, is your motor built? how is the nitrous distributed?
what started the build
https://my350z.com/forum/nitrous-oxide/245891-ouch.html
SCARY!!! hehehe
thats a lot of nitrous for a nozzle, dont try this at home.. DP FTMFW!!
i will probably be adding that lower plenum setup to my car this week. that bending line crap is for the birds!! it takes way way way way way way way way too long to do.
i can get the same setup with nylon lines though now!! i can do a full wet direct port kit with nylon lines for around 800 for the full kit. not sure what i would charge to install it yet but i will gladly do it for someone who wants it done here in florida...
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
