Compression ratio ideas?
Getting a motor built for my Z specifically to run a 200 shot. What compression ratio should I use? I don't want to lose my N/A power but don't want to blow my motor when I'm running the nitrous. Thanks in advance for any help.
Originally Posted by go-fast
when looking to determine compression ratio decide what fuel you will run and base cr on that.then build the motor to support that nitrous hit.remember unless it's a dedicated drag car you will spend most of your time with the bottle off.
Yeah I'm not going to be constantly on the bottle, but I already have a 75 shot and I use it fairly frequently. The car will be run on pump gas. We'll be using the SSV and tap each runner with a nozzle. Not sure if that affects what you guys would recommend on CR.
Originally Posted by jksstar
if you want to run a 200 shot on 93 I would think 9 to 1 (same as my motor) with a good tuner.
But would it still retain the same N/A power level with the CR that low?
you can setup a 11.7 motor to run on pump gas every day. 93 octane that is.
nitrous loves compression if it is all set up correctly.
we can put you a motor together and get it out to you. we can do it all if you want!!
give us a call or pm me if interested or have any questions..
Tochigi_236
Sep 27, 2015 03:40 PM
